What is this -- a food service facility of some kind where they need to flash-freeze their product on an assembly line?
Work 45 min inside it and go out for 15 min breaks
And I don't think there is enough room to run a 6 spd Auto under there, so it's probably a dog with presumably a 4spd behind it.
Well, my day out on the road with the F-150 turned out to be a bit of a bust! I had old Blue out for about a 100 mile drive on Monday and noticed that it was having some idle issues when I pulled up to a stoplight -- racing at times, normal at times, and even running up to around 4000-5000 rpm's if you put it in park. If you turned the vehicle off, it would start right back up at normal idle and work fine for a few miles until the problem reappeared.
At first I thought it might be a product of the truck having sat for a bit and that it would eventually work itself out. Then it threw the check engine light and I'm thinking maybe the TPS? Took it into the dealer and after checking the TPS and doing some throttle body cleaning they feel as if it is the accelerator pedal assembly that is causing the issue. Should have the new part in today and I'm hoping the issue is resolved! I'm sure glad I didn't order adjustable pedals when I bought the truck, because the price difference between an adjustable and fixed pedal assembly is significant!
Believe me -- I thought about that, thus the idea that with some additional driving it would work itself out! But once it threw the check engine light I figured it had to be more than that.
I have a similar "weird" issue with my 2009 Ranger in that my wife took it out for a drive last January and swore that the heater wasn't working. I thought to myself, "Ah, she's crazy and just doesn't know how to operate it!" But I take it for a drive myself and sure enough -- no heat!
That got me to thinking that until that one drive last January, the truck had NEVER been driven in the cold weather since I bought it new back in July of 2009, so it all that time, the heater had never been used! I'm wondering if that issue might be attributable to the fact that the blend door has been in a fixed position for so long that it is now stuck -- thus no heat?
That's another "fun" automotive issue I will have to get sorted out one of these days -- unless I decide to only drive that vehicle during the warm weather months (about 75% of the year down here in the Houston area) moving forward.....
I asked the mechanic if he thought the odd use (or disuse) of the truck might have played a role in the problem. He said he has had so many trucks (both Ford and Chevy) in for this issue once they get up around the 10-year mark that he couldn't say for sure if it's the age or the use that ends up being the primary culprit.
