Old Jun 18, 2012 | 01:33 PM
  #76096
hmmm ....a turd
yuk...
Old Jun 18, 2012 | 05:16 PM
  #76097
Been over 8 weeks and the two sides are finally going to talk. Hopefully the strike's end is near. :o
http://www.reuters.com/article/2012/...012+BW20120618
Old Jun 18, 2012 | 06:39 PM
  #76098
Let's hope so....
Old Jun 18, 2012 | 11:55 PM
  #76099
87fiveoh254's Avatar
lol I know, I know. I had some debt I needed to get out of at the time.
Old Jun 19, 2012 | 07:06 AM
  #76100
Old Jun 19, 2012 | 07:56 AM
  #76101
dsq3973's Avatar
Wow, what a difference a good nights sleep makes in how you feel.
Old Jun 19, 2012 | 08:00 AM
  #76102
Wells Fargo Financial absolutely positively SUXS!!!!
Just venting.....third month in a row where they've ran the mortgage payment two weeks early.....dumb *****....oh well another two hours down the drain trying to talk to those idiots....
Old Jun 19, 2012 | 09:31 AM
  #76103
Last time I drove the Mule, there was an oder when I shut it off. Best way to describe it, smelled just like when I used to have the old radiators rebuilt, they would dip them in caustic, the paint them. When you ran it the first couple of times, it had a very distinctive oder. This was similar. I'm think now that it could have been bakelite or something that was hot. Last night, it started up as usual and when I gave it gas to back up, it died. It never would start again. It will sit and turn over till the battery goes down, never fires off. That sounds like no fuel, but I could smell gas like it got flooded, so I am thinking electrical. Maybe coil?
Old Jun 19, 2012 | 09:42 AM
  #76104
dsq3973's Avatar
How long did it sit before you drove it Jim? I would also check the air filter box because mice like to build nests in them.
Old Jun 19, 2012 | 09:43 AM
  #76105
dsq3973's Avatar
That sucks, I have never heard much good about Wells Fargo.
Old Jun 19, 2012 | 09:52 AM
  #76106
1997 lariat 4.6's Avatar
the pickup dad and i rebuilt took its first trip down the road yesterday, we're pleased to see it move under its own power and not fall apart!
Old Jun 19, 2012 | 09:54 AM
  #76107
Last time I drove it was last Thursday. I put some oil in it last night, it was at the bottom of the crosshairs, I brought it up just below the top of the crosshairs. I poured the oil in after removing a black cap that sits on top of what looks like a cylinder head. Never seen one just like that. There are too, in a V shape, the cap is on one of them. I checked the water, and it looked good, lots of antifreeze. I know it has fuel, the gauge shows it does, plus I added some just to make sure.
Old Jun 19, 2012 | 10:57 AM
  #76108
just to be on the safe side....pull the spark plugs to see what condition they're in....also perform spark test(visual type with plugs pulled out)
Use your DMM and verify the coil is getting voltage
if its carburated it could be some gunk/varnish/debris in the bowl not allowing the needle+seat to work correctly.....check the fuel lines and tank for gunk/debris
if its a slide carb make sure the slide working correctly and the jet isn't plugged....
Old Jun 19, 2012 | 11:00 AM
  #76109
What is a DMM?
Old Jun 19, 2012 | 11:03 AM
  #76110
What is a DMM?
digital multi meter
