Old Dec 22, 2011 | 12:20 PM
  #71071
Had to sample the sausage ***** and the cheese dip. May have ruined my lunch. There is a chocolate cake covered with cherries. There is a ton of food. A peanut butter chocolate pie.
Old Dec 22, 2011 | 12:51 PM
  #71072
dirtrider596979's Avatar
i think bluejay eats better then all of us lol
Old Dec 22, 2011 | 01:05 PM
  #71073
Veteran: Army
Originally Posted by ian51279
Headed to the airport to go see my sis for 11 days. Hopefully the plane leaves on time, lots of heavy rain here. Next time I post I'll be in Texas.
lucky you
Old Dec 22, 2011 | 01:11 PM
  #71074
Jditta's Avatar
You still working at Taco bell? or was it Pizza Hut? Actually, it was Enterprise rental wasn't it?
Close, hertz. Don't lump me in with those hacks over at enterprise
Old Dec 22, 2011 | 01:16 PM
  #71075
Linch.....break time from finding leaks......
Old Dec 22, 2011 | 01:17 PM
  #71076
He eats and sleeps all day
Hey guys, I have all my original cops minus one (replaced due to misfire). I was looking on rockauto, they are 41 a piece new. I have 72k on the truck now. This summer I'd like to replace them all just to be safe. Is it easy to do? It looks like one bolt and disconnecting the harness. Is that all you do?
Old Dec 22, 2011 | 01:18 PM
  #71077
Have a safe trip....
Old Dec 22, 2011 | 01:20 PM
  #71078
Don't forget the dielectric grease, 7mm socket....
Pretty simple....
Old Dec 22, 2011 | 01:22 PM
  #71079
Headed to Damon after work tonight. About a 5 hour drive from Brownsboro. Then Christmas night, will go to Burleson, then back to Brownsboro next Tuesday night.
Drive safe....
Old Dec 22, 2011 | 01:24 PM
  #71080
Got to sleep in and passed in my last final! Did pretty damn well this semester, should be all A's and B's
Hopefully it didn't hurt too bad....
Old Dec 22, 2011 | 01:27 PM
  #71081
I need a nap!
Old Dec 22, 2011 | 01:31 PM
  #71082
Pretty simple....
Where does it get applied to? And do you replace the boots too?
Old Dec 22, 2011 | 01:32 PM
  #71083
Old Dec 22, 2011 | 02:52 PM
  #71084
Dielectric application:
1. Grease the plugs ceramic before install. This assures proper seat. Without it, the COP boot may buckle.
2. Pull the boot, then give the spring a couple tugs to make sure the spring to coil blade connection is secure.
3. Grease the entire inside of boot to protect against moisture and to focus coil pulse to the spark plug. Without it, pulse jumps, etches and leaves carbon trails inside of boots. Boots become weak and can deform.
4. Install the boot over the spring and onto the coil. With a small screw driver or curved pic, pull the spring from the end of the boot approximately onehalfinch. Slide the screw driver across the spring, keeping it from recoiling back into the boot.
5. Clean grease from spring end with a grease cutting agent. Lacquer thinner or brake cleaner works best.
6. Release spring so that it recoils back into the spark plug boot.
7. With a small brush or finger, grease the top seam of the boot.
8. Install coil.
Old Dec 22, 2011 | 05:48 PM
  #71085
Everyone must be out to Linch still.....
