Old Aug 31, 2011 | 10:18 AM
  #66181
Originally Posted by shifty219
Ive been hearing the 5.3's are bad. The other guy I was sitting with had the same problem but they said it was torn valve seals on his.
The transverse mounted 5.3's have a cold start lifter tick that doesn't go away until the oil pressurizes....gm knows of the problem and warranty doesn't cover it...
Old Aug 31, 2011 | 10:20 AM
  #66182
Breaks over
Old Aug 31, 2011 | 11:31 AM
  #66183
Micheal's Avatar
You get breaks?
Old Aug 31, 2011 | 11:32 AM
  #66184
Micheal's Avatar
Hey how come I only get smilies when I quote someone. What am I missing. Dang technology exceeds my speeds.
Old Aug 31, 2011 | 11:53 AM
  #66185
The last of my brake stuff came in today
I didn't realize they sold fronts as a set... thought they did it like rotors, so I have to return one box of them. It was "1 set, 4 pieces" so the inner and outer pads I'm assuming. Any lubricants or such I should pick up? Shanin's thread had a few things listed, but I'm not sure since I'm a 2wd
Old Aug 31, 2011 | 11:57 AM
  #66186
Micheal's Avatar
Just some disc brake grease and two cans of brake cleaner.
Old Aug 31, 2011 | 12:04 PM
  #66187
Linch......mmmm hamburgers....
Old Aug 31, 2011 | 12:05 PM
  #66188
Micheal's Avatar
thinking about subway today.
Old Aug 31, 2011 | 12:07 PM
  #66189
It all depends on the version/type of browser(not having plug ins or ad blockers) and if your using f150's mobile or traditional platform.....
Old Aug 31, 2011 | 12:13 PM
  #66190
Sounds good. I'll have my usual. Cheese sandwich, Cheetos, apple, cashews and almonds and a Diet DP
Old Aug 31, 2011 | 12:29 PM
  #66191
Alight, thanks Michael. What about extra brake fluid for when you open the bleed valves?
Old Aug 31, 2011 | 12:32 PM
  #66192
Oops......
Caliper slide lube
Pad silencer
Brake cleaner
Brake fluid
Old Aug 31, 2011 | 12:34 PM
  #66193
When the calipers are compressed you'll get some back in the resivor....have some new for just in case.....you should need to open bleed valves unless you're changing a caliper or changing all the fluid....
Old Aug 31, 2011 | 12:42 PM
  #66194
The doofus that made my cheese sandwich this morning didn't put enough mayo on it. He must have been half asleep.
Old Aug 31, 2011 | 12:45 PM
  #66195
Ok thanks 88, quick thing though. So the box had 4 pads in it, I'm reading Shanin's writeup and her's is showing one pad per rotor... do the 2wd's have an inner and outer pad?
