Old Aug 31, 2011 | 12:47 PM
  #66196
Ok thanks 88, quick thing though. So the box had 4 pads in it, I'm reading Shanin's writeup and her's is showing one pad per rotor... do the 2wd's have an inner and outer pad?
all rotors have an inner and outer pad. So, there are 4 pads for the front and 4 for the rear.
Old Aug 31, 2011 | 12:51 PM
  #66197
So I'm not crazy, I didn't see it on her writeup though
Old Aug 31, 2011 | 12:53 PM
  #66198
I guess she thought you would know that already or at least would know to replace what comes off. The pads actually squeeze both sides of the rotor.
Old Aug 31, 2011 | 12:59 PM
  #66199
Yes all disc brake assemblies have inners and outers.....they work like a sliding "C" clamp if you want to think of it like that...
Old Aug 31, 2011 | 01:01 PM
  #66200
I knew it had 4 pads, but when I didn't see it, I started wondering if I was somehow mistaken... you need the force of both. If you didn't you'd have one warped rotor and horrible brakes
Old Aug 31, 2011 | 01:02 PM
  #66201
Oh and for the brake fluid, any recommendations? I'm going to hit advanced today
Old Aug 31, 2011 | 01:05 PM
  #66202
ehhh well the rotor applies pressure, and the pads are moved against the rotor on both sides, but the pads are not responsible for "squeezing"
spec is DOT 3, so you can use 3 or anything higher, but unless you're doing a full system flush i would just leave it as 3. But you really shouldnt need much at all, since when you push the caliper back in, the fluid goes back into the reservoir.
Unless you're doing a bleed or flush you shouldnt need any new fluid.
Old Aug 31, 2011 | 01:06 PM
  #66203
Unless you plan on flushing the fluid, you should not need any brake fluid. If you don't break the lines open, you don't lose any plus there is no need to bleed them. I have changed pads twice on my 05 and never added fluid.
  #66204
Actually by your line of thought there would be four warped ones.....
Old Aug 31, 2011 | 01:08 PM
  #66205
put your finger in there and see if the pads don't squeeze. technical turd.
Old Aug 31, 2011 | 01:10 PM
  #66206
Sorry, ASE Master Tech here, just trying to stay factual
Old Aug 31, 2011 | 01:13 PM
  #66207
Originally Posted by 88racing
Oops......
Caliper slide lube
Pad silencer
Brake cleaner
Brake fluid
Ok I found these
CRC Brake and Caliper Grease
CRC Brake Quiet
Old Aug 31, 2011 | 01:14 PM
  #66208
if you use Wagner TQs, you do not use the quietner stuff.
  #66209
you should only need to grease the caliper slide pins, but other then that, nothing else is needed
Old Aug 31, 2011 | 01:15 PM
  #66210
Ok sounds good, that is what I was seeing online
Doesn't the fluid get "old" after a while though?
Someone is "Mr. Technical"
