I have discovered ice . . .
This can't be good . . . .
here's my across the street neighbor . . . that's a good sized branch(es) down
here's now much thicker the ice has gotten on the branches
Here's the ever-growing icicles on the tool shed
Yup, right before I do.
Originally Posted by Zen Philosopher Zaairman
Which begs the question, if a tree limb falls on Kobi, does it make a sound?
Originally Posted by Zaairman
Moral of the story, stay inside by the fire.
You do have a fire going, right?
Not yet. Need kindling as the gas starter is not hooked up yet. Used all the kindling I had (which was someone else's) to start the test fire (in the pix from the other day).
If the power goes off, I will find a way to start a fire.
Thankfully, I had all the firewood stacked in the tool shed . . . where it is nice and dry.
Originally Posted by CANES676400
dont trees explode cause they freeze
ETA: Kobi, use newspaper along with small pieces at first. Once that gets going, add larger pieces.
No way . . . that's the silliest thing I've ever . . . .
oops . . . .
never mind. My bad. I stand corrected.
Carry on.
You wouldn't happen to have a family member who is currently having problems with a Yorkie would you?
I'm changing my name to Matt (not Mag, the other one).
Go to Wal-Mart, Lowes, True Value stores all carry some variation of these.
I use 1/2 a stick and can light logs, sticks, even damp.
Just light it an end, lay it in the fireplace, stack wood on top of it and in 20 mins or less, (depending on wood type, size and dryness) you've got a blazing fire.
Of course that does mean you'll have to drive......
I took teh family for a scenic drive through the icy landscape this afternoon. Watched turkey and deer, wishing I had a gun, did have a camera so snapped a few snap shots, need to see if they came out, if they look alright then I'll post pics.
Originally Posted by wild-mtn-rose
They don't explode in a showy fireball, no, but sharp temperature changes between day and night can freeze the water inside the trunk of a tree, causing it to split open. If you go out on a night when it's in the teens or below, after a warmish sunny day (warmish being relative here, I'm talking 30° or so!) you can hear the trees cracking, it's kinda spooky sounding.
24 bricks equal 48 fires.
As far as generators go there are different sizes that will run 3, 4 ,5 or more items without bogging down.
My relatives in the Northeast have a 'wholehouse' generator. An electrician wired it into their circuit box.
They lose power weather related, for several days at a time and just throw a switch and everything in their house works.
They don't have to pick and choose like me.
