Why 4WD?
Old May 22, 2006 | 10:43 PM
  #31
ChrisT's Avatar
Originally Posted by KickinBlue4x4
If its a 6 banger and 2 wheel drive its not a truck. It just thinks its one.
OUCH MAN!!! Below the belt! Eh, I guess I'd half to agree with you but I did by mine new when I was 22. I will agree with everyone else, my next truck will surely be a 4x4.
Old May 22, 2006 | 11:46 PM
  #32
KickinBlue4x4's Avatar
Originally Posted by UrbanCowboy
IMO, if it has girly 1997 style curves; it's not a truck.
IMO My girly turck beats yours down a dragstrip, up a hill, through a mud puddle and IMO it looks better and sounds better doing it!
Old May 23, 2006 | 12:09 AM
  #33
Zaairman's Avatar
Why a 4x4? The look, the ride, the confidence. I've done things in a 2wd that some people wouldn't do in a 4x4. i can't wait to see what I'll do when I finally get a 4x4
Old May 23, 2006 | 12:14 AM
  #34
To each his own... But let me ask you, if you like the look, ride and confidence(?) Why will you be going to a 4x4? I like your sig BTW.
Old May 23, 2006 | 12:26 AM
  #35
Zaairman's Avatar
Thanks, Bill (Wstahlm) made it for me, and I'll be going to a 4x4 because there's some things that I don't want to do in a 2wd, I've been stuck before and it sucks. I like to have the fun, not be the recovery truck. It won't be happening for a few years though, gotta finish college first, or so I keep telling myself.
Old May 23, 2006 | 12:35 AM
  #36
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
YAWNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
Old May 23, 2006 | 03:05 PM
  #37
machgt's Avatar
it was a choice between 4wd and the 5.4 and I chose the 5.4 so I could tow some things. I'll get a 4wd truck sometime down the road but the 4x2 does fine for me with some sand bags in the back in the winter.
Old May 23, 2006 | 10:01 PM
  #38
jljue's Avatar
Originally Posted by captain morgan8
because these are heavy trucks and I dont wanna get stuck in wet grass and to help pull my 28' boat out of the water.
I've been fortunate that I haven't needed to go to 4-Hi to pull a boat out of the water since the ramps that I normally launch from don't have that much angle, but I did have to use 4-Hi to take advantage of a really good parking space a couple of times down below the spillway.
Old May 24, 2006 | 12:31 AM
  #39
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
I thought I was stuck once while pulling mine out last year, the ramp is steep, but the starter went out on the boat and I had to load it by hand. So I backed the trailer to the end of the concrete which put my rear tires in the water. I was able to get the tires out of the water but as soon as the boat landed on the trailer the wet tires would loose traction. I stuck it in second and slipped the crap out of the tranny belts and was able to get a little further but couldnt get the boat all the way on the trailer and out of the water. Finnaly just hammered it till I seen a little bit of smoke, stopped and then it pulled it on up with no problem once the tires were dry.
Old May 24, 2006 | 10:18 PM
  #40
jljue's Avatar
Dad's dropped the trailer off the end of the ramp before, but 4-Lo on his '85 S-10 Blazer wouldn't even do the trick. He had to get some guys to tie ropes to the back of the trailer and have them pick up on the trailer while he pulled forward.
Old May 25, 2006 | 12:05 AM
  #41
PSS-Mag's Avatar
I ripped one of my cross braces on my trailer because I droped it off the side of a narrow ramp. Luckily boat wasn't on it so it came up with 2wd just fine. Few zaps with some metal glue and it is new again.
Old May 26, 2006 | 04:54 PM
  #42
Zaairman's Avatar
Why is it you never have good luck with your boat?
Old May 27, 2006 | 10:39 AM
  #43
98Navi's Avatar
Because I can.
Ever seen a blown navigator on street tires slinging mud? Me niether
Old May 27, 2006 | 11:05 AM
  #44
NIUPonyBoy's Avatar
I wouldn't buy a truck without it.
Old May 27, 2006 | 11:56 AM
  #45
UrbanCowboy's Avatar
Dragstrip? It's a truck; not a racecar
Up a hill? I bet I can pull more up said hill
Mud Puddle? Not likely
Looks Better? If you're a woman
Sounds Better? Doubtful.
Wanna climb some boulders? Lets play!
