Brain Teaser - Will it take off??
Originally Posted by Stealth
You know, if this conveyor system actually worked then they would use it on aircraft carriers and not use the catapult system on aircraft carriers to launch jets from the flight deck. That's what makes this entire argument so hilarious.
I know I'm coming in late, but I refuse to go back and read all the arguing. I know you people are smart.... It doesnt matter if the surface the plane on is moving forward, backwards or still the planes wheel bearings are the only thing that would transfer that force to the actual plane. The plane will take off like it always has
Originally Posted by Wookie
Why so the plane would take as long to get off a carrier deck as it would on a land runway?
When landing on a carrier deck the plane hooks on a catch cable which aids in stopping its momentum on the short deck.
So when a car is on a 4 wheel dyno how fast is the car going when the speedometer is reading 60 MPH? Answer, the car won't be moving at all. It will be sitting still.
Imagine a jetbike on a motorcycle dyno. How fast do you think the wheels will be spinning with the engine at full throttle? Answer, they won't be spinning at all, just the jet engine will be creating thrust.
Originally Posted by styxnpicks
60, but this is what you DONT UNDERSTAND, a car is not a plane, apples to oranges.
You cannot understand the obvious logic involved here, that is the problem.
A plane cannot fly if there are no aerodynamics present.
Originally Posted by scott1981
0. Until the tires transfer power into fwd momentum your just wasting energy
It's the same principle. Sheez. I think your bilstiens rattled something loose.
your logic is wrong, but you are to stubborn and proud to realize this, and the sad thing is the more you ramble on trying to prove you point the dumber you look, because you are not looking at all the forces in play here
Same as the jet on the conveyor system. The plane will be going 0. It won't take off.
The conveyor would not effect a plane. The bearings are made to roll freely and will not transfer movement to a plane. The planes tires will just free roll 2x the speed of the planes actual speed until it takes off.
