Brain Teaser - Will it take off??
Old Feb 2, 2008 | 02:35 PM
  #241
styxnpicks's Avatar
Originally Posted by Stealth
There are many forces at play here. Thrust, gravity and aerodynamics, along with the conveyor rotating opposite of the wheel speed. The conveyor is simulating the movement of the ground as the thrust of the engine pushes the plane forward, but the plane isn't actually moving forward, so there are no aerodynamics on the wings, so it won't fly. I'm not the stubborn one here.
yes you ARE the stubborn one, because you are not fully comprehending the way the myth is worded. your just to proud to realize it, kinda funny cause you REALLY look stupid right now, bacuse you don't realize that in order for the belt to move backwards the plane HAS TO MOVE FORWARD that is the way the myth is worded , look at it again. if the plane moves forward... the belt moves the same speed and distance in the opposite direction. and if you understood the forces you would know that the force of drag involved here is WAY less than the force of thrust
Old Feb 2, 2008 | 02:37 PM
  #242
Tumba's Avatar
The plane is moving forward , it is not tied down.
Old Feb 2, 2008 | 02:38 PM
  #243
It seems you are confused. The belt moves backwards, see below. I refuse to belittle you though.
Originally Posted by OP
"A plane is standing on a runway that can move (some sort of band conveyer). The plane moves in one direction, while the conveyer moves in the opposite direction. This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in opposite direction)."
Old Feb 2, 2008 | 02:40 PM
  #244
styxnpicks's Avatar
so what don't you understand about the belt moving the same speed as the plane in the oposite direction?
Old Feb 2, 2008 | 02:41 PM
  #245
scott1981's Avatar
Exactly, The wheel bearings are the only items transferring the speed of the conveyer belt to the plane. Mythbusters just did this and the plane took off
Old Feb 2, 2008 | 02:42 PM
  #246
I understand it completely. The speeds are cancalling each other out, therefore the plane is wasting forward energy, and not moving.
Old Feb 2, 2008 | 02:43 PM
  #247
The MB experiment episode was obviously flawed. This does happen.
Old Feb 2, 2008 | 02:44 PM
  #248
So why don't they use this conveyor ststem technology on any aircraft carriers?
Old Feb 2, 2008 | 02:49 PM
  #249
styxnpicks's Avatar
you don't understand the concept. the plane will fly down the runway at the same speed, rotate at the same point, and lift off at the same point. the ONLY difference is the "ground" will be moving at twice the normal speed, so really the wheels would be spining at twice the speed, thats it thats the only difference, i will let you make a fool of yourself now
  #250
Net Wurker's Avatar
Because if a plane needs 500 feet to take off from a fixed runway, then it will need 500 feet to take off from a conveyor runway. What would be the point of adding a complicated conveyor runway?
Old Feb 2, 2008 | 02:53 PM
  #251
Exactly. These guys are making it seem like the plane can be sitting still and just take off conventionally only because of engine thrust.
Old Feb 2, 2008 | 02:56 PM
  #252
styxnpicks's Avatar
Ecactly.
... thats 500ft true ground speed in relation to the earth. it would take 1000ft of "belt" runway,
an no we are NOT tring to make it seem like the plane can be sitting still and just take off conventionally only because of engine thrust
bacause the PLANE WILL NOT SIT STILL!!!!!! it WILL move forward in relation to the earth
Old Feb 2, 2008 | 02:59 PM
  #253
BUT the wheels will rotate on the belt making the plane act as if it's NOT MOVING. It is on the belt which is simulating the ground, but the plane is not actually moving, the belt is. The plane is stationary.
Old Feb 2, 2008 | 03:01 PM
  #254
styxnpicks's Avatar
Yeah, because it's doubled, it is a belt.
right but the plane will still move forward 500ft in relation to the earth
watch this from 7:50 till the end and you will totally understand
http://www.youtube.com/watch?v=MuXK1...eature=related
  #255
last5oh_302's Avatar
