Brain Teaser - Will it take off??
Old Feb 1, 2008 | 03:23 PM
  #166
06F150STX's Avatar
yes it will take off. the plane is driven by thrust, not by the wheels. so, yes, it will take off.
Old Feb 1, 2008 | 03:25 PM
  #167
Thrust combined with lift. If there were no flow of air over the wings there would be no takeoff, regardless of thrust.
Old Feb 1, 2008 | 03:30 PM
  #168
crash_lucky13's Avatar
LOL just saw this on mythbusters.... go figure
An airplane cannot take off from a runway which is moving backwards (like a treadmill) at a speed equal to its normal ground speed during takeoff.
busted
First some small-scale tests were performed with a model airplane on a treadmill and the plane was able to take off. For the large-scale test, the MythBusters used a 400 pound ultralight aircraft with a 2000 foot tarp under it. The tarp was pulled backwards to simulate a moving runway. The ultralight pilot had no trouble taking off. This is because the thrust of the airplane engines acts on the air, not on the ground.
http://mythbustersresults.com/episode97
wow, i feel soooo cool...
Old Feb 1, 2008 | 03:41 PM
  #169
KSUWildcat's Avatar
busted
They cheated.
Signed, The Naysayers.
Old Feb 1, 2008 | 03:52 PM
  #170
Wookie's Avatar
Originally Posted by Stealth
No, a wee cessna takes off just as easy as a loaded c130, but neither as hard as an f-16. An f-16 is like a rocket with a pilot on it, aerodynamics are not as good.
The type of aircraft has absolutely no bearing on the equation. A Piper Cub flies the same as an A380. Sure the A380 takes more thrust to take off but the equations that govern flight are the same.
Old Feb 1, 2008 | 03:57 PM
  #171
No kidding, the equasion is flawed. Lift isn't generated by a treadmill.
Old Feb 1, 2008 | 04:26 PM
  #172
Wookie's Avatar
The problem is not with the equation, it's the vacuum in your head.
Old Feb 1, 2008 | 04:30 PM
  #173
So, every time I drive the flight line at work and they are engine testing an f-16 or the f-35 that is tethered to the ground and the jet turbine engine is at full throttle and the tethers broke loose the plane would instantly become airborne? I think not, rather, i know not.
Old Feb 1, 2008 | 04:50 PM
  #174
kingfish51's Avatar
Originally Posted by jiggle
Take a course in aerodynamics and propulsion systems. Then it will make sense. The airplane flies. Period. It doesn't matter if the wheels are spinning zero, 100 or 1000 mph, nor does it matter which direction the wheels are spinning. What matters is that the engine is pulling (or pushing) against the AIR, not the GROUND. The powerplant would only have to overcome the extra friction from the wheels spinning at a higher rate of speed, but that is negligible.
Reread my statement. If the plane has a 0 over the ground speed, unless it has a 100mph headwind, it is not going to fly. Yes if it is going at 200mph IN RELATION TO THE CONVEYOR, which is going 100mph, then it has a 100mph over the ground speed, and will move in relation to me at 100mph. In that instance, unless it has a 100mph tailwind, it will fly.
Old Feb 1, 2008 | 04:57 PM
  #175
Liken the conveyor theory with the engine at full throttle to the plane being tethered to the ground at full throttle. The plane won't fly because it is sitting still.
Old Feb 1, 2008 | 05:06 PM
  #176
Wookie's Avatar
Nope, it would start rolling. As it rolls along it will accelerate. Once it accelerates enough it will reach a speed great enough for the wings to produce sufficient lift and the airplane will over power gravity.
Old Feb 1, 2008 | 05:11 PM
  #177
You must have missed this. I think you're the one with the vaccuum problem.
Old Feb 1, 2008 | 05:19 PM
  #178
06F150STX's Avatar
it doesn't matter how fast the convayor is moving. it can be moving even faster. the thrust will push the plane forward. theres your wind to lift the plane.
Old Feb 1, 2008 | 09:11 PM
  #179
CDB03STX's Avatar
This is a hopeless case..... Thanks for the MB link...I have to send it to my boss and another freind who is a pilot himself.
Old Feb 1, 2008 | 09:24 PM
  #180
not a problem...
guys calm down... this is one of the biggest controversies ever...
heck the PILOT of the PLANE for myth busters said there was NO WAY that he would take off... he was more surprised than anyone....
ya'll really need to watch the WHOLE episode...it's really really good.
