2015 Super Duty in detail
Though I posted this already, but it got lost. Anyways, check out the details:
http://www.autoweek.com/article/2014...NEWS/140309917
Key points: F-450 has a GCWR of 40,000 lbs with a max tow of 31,200 lbs. when properly equipped. That tow rating goes down slightly as you add options of course, but it looks like the Ford will be the new king. As we know, this will be a true F-450 so GVWR whould be up meaning payload will be up. This trucks starts at 8,800 lbs so hopefully a GVWR of 16k+. It will need that payload capacity otherwise that big tow rating is a gimmick (see dodge 3500)
The F-350 will get an additional 3300 lbs. This should bring it closer to 28,000 lbs. Although smaller than the 3500 Dodge, REALISTIC 5th wheel capacity should be the same.
Then there is the Engines. Ford is tauting 440hp and 860 Tq but most importantley, much improved engine braking.
The new medium duty trucks are sexy! They get the new engine as well as the fan-favorite 6.8 V-10. Didn't see any info on gas engines for the super duty trucks.
The F-750 looks to be an awesome tractor for shorter hauls. It would be cool to see a
v-10 based off the coyote but Ford would be more likely to expand the ecoboost line
for those that don'twant a diesel. Right now the 6.8 v-10 is still king for commercial gas. Who here is hoping for an Ike Gauntlet run using the same as what the Dodge towed?
