swapping factory exhausts
Old Aug 30, 2011 | 01:31 PM
azmidget91's Avatar
05+ have 2 cats
Old Aug 30, 2011 | 01:34 PM
97isnotold's Avatar
so you think if i got an exhaust from a junkyard for a 4x4 05+ and hook it up to the rest of my exhaust everything would fit up?
Old Aug 30, 2011 | 01:38 PM
azmidget91's Avatar
yes, but will be easier to just cut out the rear cats
Old Aug 30, 2011 | 01:40 PM
97isnotold's Avatar
ok. then i might just take mine out and cut them off and weld in some straight pipes if it's not too hard to get it unbolted from the manifold
Old Aug 30, 2011 | 01:42 PM
azmidget91's Avatar
while you are at it replace the fronts with hi flow cats, then sell your 4 cats to the scrap yard and you will probably make money on the whole deal, hi flows are about $60-70 depending on where you get them and which ones, then a scrap yard should give you about $50 per cat so spend $140 on cats and sell your stock ones for $200, make $60
Old Aug 30, 2011 | 01:45 PM
jlyoung08's Avatar
you know alot man lol
Old Aug 30, 2011 | 01:48 PM
azmidget91's Avatar
ive been tinkering with these f150's for quite some time now
jlyoung08's Avatar
ive never messed with any exhaust upfront like cats but done it all in the rear
Old Aug 30, 2011 | 01:56 PM
azmidget91's Avatar
i have long tube headers hi flow cats and a single 3" exhaust dumped. this past weekend i actually just replaced my cats with new hi flows because the old ones went bad
Old Aug 30, 2011 | 03:46 PM
97isnotold's Avatar
this sounds like a plan. i might have to do this
Old Aug 30, 2011 | 04:04 PM
Your plan is investing a lot of money for a slightly louder sound. Remove your OEM rear cats if anything. I did with my '04, which will not throw a code. Front cats & true dual Bullets blow away a Flowmaster also, just in case you want it a lot louder.
http://www.youtube.com/watch?v=Vi-L12mt5E4
Old Aug 30, 2011 | 04:13 PM
Need4racin's Avatar
Darren you're really bad about slamming doors. Your truck isn't a 1920 dumptruck. LOL
Old Aug 30, 2011 | 05:06 PM
97isnotold's Avatar
well i could get a mid pipe from a junkyard for $50-70
