swapping factory exhausts
Old Aug 30, 2011 | 12:13 PM
97isnotold's Avatar
if im not mistaken the 04-05's have 4 cats and 06-08's have 2 cats and i was wondering if i could swap my exhaust for an 06-08 with 2 cats from where it bolts on to the manifolds to the mid pipe. i have a flowmaster 10 si/do and it's not nearly as loud as an 06 with 2 cats and the same setup.
Old Aug 30, 2011 | 12:25 PM
jlyoung08's Avatar
dont feel bad that mines louder lol
Old Aug 30, 2011 | 12:28 PM
97isnotold's Avatar
im so jealous lol i want that sound, i think it'd be easier to swap a stock exhaust from a junkyard than hi flow cats
Old Aug 30, 2011 | 12:29 PM
jlyoung08's Avatar
prolly would...is there any o2 sensors on your back cats?
Old Aug 30, 2011 | 12:33 PM
97isnotold's Avatar
yep, 4 O2 sensors but if i swapped and ran codes i could erase it
Old Aug 30, 2011 | 12:36 PM
jlyoung08's Avatar
hmmmm...what if u got those o2 delete things?
Old Aug 30, 2011 | 12:37 PM
97isnotold's Avatar
the 02 spacers? does yours have 2 or 4
Old Aug 30, 2011 | 12:41 PM
jlyoung08's Avatar
2....jus unbolt it all and leave them hangin under your truck and run open manifolds...theres no way thatd be bad for it lol
Old Aug 30, 2011 | 12:47 PM
97isnotold's Avatar
i mean if i wanted to i could unbolt the exhaust and weld in two hi flows myself or just gut the rears but still
Old Aug 30, 2011 | 12:58 PM
azmidget91's Avatar
going from 4 to 2 cats will not throw a code...
Old Aug 30, 2011 | 01:06 PM
jlyoung08's Avatar
even with 4 sensors?
Old Aug 30, 2011 | 01:07 PM
azmidget91's Avatar
yep, all 97+ f150's have 4 sensors
Old Aug 30, 2011 | 01:17 PM
jlyoung08's Avatar
figured since mines 06 i only have 2 cats so id only have 2 sensors...i may have 4 sensors but ive never noticed?
Old Aug 30, 2011 | 01:21 PM
azmidget91's Avatar
yes, you have 4, 1 before each cat, and 1 after each cat
first one reads the a/f the second one is for emissions, that is why the rear 2 cats (which are mounted after the second o2 can be removed, there is no sensor after them to see if they are there or not
Old Aug 30, 2011 | 01:27 PM
97isnotold's Avatar
but do the 06+ only have 2 cats?
