Single 3" ..Advice...
Hi all..I'm trying to get back up to speed on the F150's..Been in a Ranger for the past few years..Now with the 05 I just picked up, I would like to do some exhaust. I think I just want a single 3" after the stock y and a 3" dynomax bullet single..
I want some good sound but not a TON of sound..Going to be hauling around a baby soon..
Does this sound like a good set up?
interesting
Up to 2008 models yes. I actually think '97 - '03s had a better flowing Y pipe. Not quite sure if '09+ models are just as bad with their full 2.75" exhaust.
Interesting.... Ive been living under a rock i assume
So what size of Y pipe upgrade would be good enough for a Si/DO 3" Dynomax bullet with 3" pipe
3" ??? Yes i know i might be asking a dumbA$$ question but i hear this and i hear that about different things and can never find an answer to my question
I appreciate your input Punisher
Here's a picture that I made a week ago for another member. Just pretend "Magnapack" means Bullet and that stick man isn't being a *****.
3" pipes for a SISO are just the best performing across the whole RPM range. The stock 2.5" pipes are good but offers no room for improvement.
97-03's - The turn right @ the bank 2 sensor reduces down to 2.25. Yea, that sort of ruins it. It's not all bad tho. Troyer had gains on the Dyno across the board,- just adding a 3" cat back to an otherwise factory OEM system.
So, RIGHT AFTER the Y, you go up to 3" into a straight thru muffler and mandrel bent tailpipe w/4" tip (progressive) . That was the system to benefit the 97-03 V8's. I believe they still have it here, -
http://www.troyerperformance.com/cgi...atalogno=15609
They have a few more to choose from for your model here -
http://www.troyerperformance.com/cgi...stems&start=40
