long tube headers questions
Old Sep 9, 2010 | 07:26 PM
RebelOne's Avatar
I have an 05 f150 4.6 2wd. Pacesetter says they only sell them for a 4wd. Is there a difference in them? Is it alright to get them? They're only $300.00
Old Sep 10, 2010 | 02:08 PM
avfrog's Avatar
search engine
Old Sep 10, 2010 | 03:00 PM
Veteran: Army
I posted some a while back...
Old Sep 11, 2010 | 10:36 PM
RebelOne's Avatar
thanks for the lack of help fellas. Like I didn't search for the damn answer first.
Old Sep 12, 2010 | 08:12 AM
Veteran: Army
sorry I didn't spoon feed you, if you clicked on my profile, then statistics, then all threads started by me, you'd have found this
https://www.f150online.com/forums/se...archid=3869682
you need to click on this one https://www.f150online.com/forums/ex...fo-inside.html
hopefully you are helped now
Old Sep 12, 2010 | 09:17 AM
dirtrider596979's Avatar
i have the obx long tubes, they were 500 but come with resonators and all the tubing to the y pipe or x pipe. i would definatley buy them again, there on ebay
Old Sep 12, 2010 | 11:30 AM
Those $300 pacesetters are going to rust out nomatter what climate you are in, and the welds may eventually leak.. Save yourself some hard labor and do it the right way first, get stainless steel headers. OBX, or Dynatech.
Old Sep 12, 2010 | 02:34 PM
RebelOne's Avatar
and still, no answer. I was asking if 4wd and 2wd use the same headers. Its a damn simple yes or no question. I didnt want info on stainless works, obx, or dynatech ****.
Old Sep 12, 2010 | 10:04 PM
avfrog's Avatar
^ No they are not the same, and a simple search would answer the question as of why. Let me sum it up for you. 4x4 has a transfer case. Longtubes for a 4x4 are designed to work around it.
Old Sep 13, 2010 | 12:06 AM
RebelOne's Avatar
This forum sucks...i know it is designed to go around the transfer case. I am asking if they will fit the 2wd model also. Pacesetter themselves don't know, Ford don't know, none of the part stores know. This is why I'm on this asking people.
Old Sep 13, 2010 | 12:56 AM
longbed99's Avatar
who sucks? Are you the result of kissing cousins? No trucks? Good idea.
sgray's Avatar
Is that a complete kit-headers and y-pipe? I dont see why the pipes that go around the transfer case wouldnt work on your 2wd.
On another note, I would have to agree with Darren. Spend a little extra cash and either go with OBX or Dynatech. Ive got the Dynatech setup on mine and they have been awesome.
Old Sep 13, 2010 | 06:36 AM
jbrew's Avatar
And th OBX's won't ? They rust from the inside out. My headers are fine after 3+ years and their longer + heavier gauge than OBX. My trucks allot quicker since I added these.
I could beat on OBX but why, you get your money's worth with either set.
You can get PS's Ceramic Coated or have them Jet Coated. I've never heard of welds going bad. I call BS. Their very easy to weld because their heavy. If those welds leak, like with any header install, it's most likely due to the install (stressed) and/or incorrect dampening.
Dynatech, Kooks - Those are all quality, - there's only a few I know that run Kooks. One, -a member of this site, -runs them on his 4six. Dynatech's are easier, -bolt on + kits.
Old Sep 13, 2010 | 06:42 AM
jbrew's Avatar
Yes, they'll fit.
If they don't, -lets us know ehh.
Old Sep 13, 2010 | 07:56 AM
FATHERFORD's Avatar
You realize OBX's are stainless, and are dynatech knock offs right? The ONLY difference is OBX has a 2.5" collector and Dynatech has a 3"?
There for, you are contradicting yourself by saying OBX's are junk and Dynatechs are better.
