Side Exit Exhausts
Old Aug 7, 2010 | 05:53 PM
Vigs07R's Avatar
Side Exit Exhausts
I am thinking about switching to a side exit exhaust the dumps right before the rear tire. My only question is have any of you that have this setup have any problems with the exhaust fumes messing up that rim?
Old Aug 7, 2010 | 06:16 PM
Hal65ford's Avatar
I have stock rims on my truck and it hasn't done anything to the rims but i melted the ford logo in my center cap. but if you have after market rims it wont do that because most likely your after market rims are wider. You can see my setup on my profile.
Old Aug 7, 2010 | 10:32 PM
basadochi04's Avatar
I have DC-1s on my 150 and have had it out the side right in front of the tire for a while now and no problems. I really like it. I have 2.5 in pipe manderel bent out he side with 4in tips and a short bodied maggy. Sounds good and a nice tone at idle.
Old Aug 7, 2010 | 11:21 PM
avfrog's Avatar
It won't hurt your rims. I have no idea where this rumor came from...
Old Aug 8, 2010 | 05:56 AM
batn68's Avatar
i ran a single tip exit in front of the wheel for one year, and no problemos. I now have dual tips and still nothing. Rocks do seem to ping the heck out of the tips though, kinda hard sometimes.
Old Aug 8, 2010 | 06:57 AM
devintaylor63's Avatar
i have side exit exhaust on my 05 f150 dual echo tips nothings wrong with my rim or tire
Old Aug 8, 2010 | 08:56 AM
StealthF150's Avatar
I've had Magnaflow for 2 years now w/custom rims. Never had a problem.
Old Aug 8, 2010 | 09:23 AM
4x4wolf's Avatar
I've had my gibson coming out in front of the rear tire for 3 years now with aftermarket rims and no worries. I have seen a diesel with this setup and yes that did cover its rims but on a gasser no problem.
Old Aug 8, 2010 | 11:42 AM
hockeyfanjeff's Avatar
From Ford. Back when the 97's had the factory single side exit before the tire. They issued a semi-recall for it. Basically if your rear passenger wheel was being discolored they would replace it with a normal rear exit.
Old Aug 8, 2010 | 02:40 PM
Vigs07R's Avatar
Yes that is what I heard and wasn't sure if it would still cause an issue
Old Aug 8, 2010 | 03:11 PM
LincolnMarkLT20's Avatar
I have side exit before the tire with 20" wheels, no problem at all.
Old Aug 8, 2010 | 03:30 PM
Hespen537's Avatar
I always wondered this myself. I had never had this problem after I put it on. So your pretty safe. Unless swap with a diesel engine. Then you might have problems.
Old Aug 8, 2010 | 03:35 PM
Here's a write-up on some research I did regarding this topic awhile back when I converted to a side exit exhaust system: https://www.f150online.com/forums/ex...omparison.html
Old Aug 8, 2010 | 04:45 PM
migdaddy's Avatar
The only issue you might have (if the tip is installed too close to the tire) is the heat from the tip heating up the tire. I never had an issue though.
Old Aug 8, 2010 | 05:16 PM
avfrog's Avatar
OP- If that is the look and sound your after, then do it and quit worrying about it. There are hundreds of people running exhaust in front of the rear tire, and I have never heard of any of them having any problems. Not just f150's either...
