louder...
Old May 26, 2010 | 11:06 PM
cortinas's Avatar
louder...
as of now i have the series 40 flowmaster SI/DO, i removed the rear cats a sometime ago and it did make a huge difference but i really want to make it louder at start up and WOT, i love the sound but not loud enough. any suggestions?
Old May 26, 2010 | 11:15 PM
3" Dynomax Bullet, mated with a Y pipe to your tailpipes.
Watch 2:15 - 3:34 for cold, mild, and warm starts, and the rest for the sound.
http://www.youtube.com/watch?v=Jo4eXYrCwRQ
Old May 26, 2010 | 11:30 PM
avfrog's Avatar
If you want to keep the flowmaster and make it louder... Cut off the tail pipes at the muffler and do NOT put on turn downs. Leave the end of the muffler open. You will love it, and I'm not joking!
Old May 26, 2010 | 11:34 PM
cortinas's Avatar
man that thing sounds mean, you also have true duals tho, i dont have the money right now. eventually i will deff. swap, you have high flows? will it help me out?
Old May 26, 2010 | 11:50 PM
Technically yes, the stock pre-cats. They are basically a hi-flow cat as is, short length, no sound resonating, and on our models they are the only cats O2 monitored. Cut the rears ( which you have already done ) and you have hi-flows. So you already have hi-flows. No need for changing, unless you got LTs which would physically need new cats that aren't elbow shaped.
Old May 27, 2010 | 06:39 PM
aPINCHbetter90's Avatar
I second this option, I had a Flowmaster 40's series on and I swapped to a dynomax bullet and it was everything I wanted it to be. All I had to do was cut that muffler out then do just what darren said is put a Y pipe off your Dynomax. Its easy to do and it sounds just like a 40's series but louder at start-up and just cruising speed with nearly the same tone.
Old May 27, 2010 | 09:16 PM
Hell yeah man
Old May 28, 2010 | 08:28 PM
frdrdr4life's Avatar
i also have a 40 series flowmaster with 3 inch piping and turn dwn and i also want somthing louder but i dont want to break the bank so whats the cheapest thing i can do new muffler..exhaust cut out...or high flow cats?
Old May 28, 2010 | 10:38 PM
avfrog's Avatar
^ cut off turn down
Old May 29, 2010 | 11:56 AM
Cheapest thing to do is just cut out your flowmaster and put in a dynomax bullet and if you have duals put a Y pipe on. It will make it much louder to what you want.
Old May 29, 2010 | 06:19 PM
well i thot that u needed a turn dwn cause if not wouldnt the exhaust fumes melt the spare tire and harm the reer suspention? will the dynomax bullet si/so turn dwn sound any louder and better then my set up i have now
Old May 29, 2010 | 06:34 PM
Veteran: Army
what tips are you running?
Old May 29, 2010 | 07:45 PM
98infinity's Avatar
I thought the same thing, but my spare is in the bed.
Old May 29, 2010 | 07:53 PM
Dnasty777's Avatar
I've ran an open muffler and it destroyed my left rear shock. Completely rusted now. I personally wouldn't recommend it. Just my $.02
Old May 29, 2010 | 08:46 PM
Turn downs are usually required to help it pass visual inspection, the exhaust exit needs to be after cab, and not blowing toward the spare or axle pumpkin to pass. Turn downs that are angled right down,and too long kill sound.
Patman on here ran a SI/SO for a long while with a very tiny turn down/dump off and it roared loudly.
