Oem exhuast manifold broken.
Old Feb 25, 2010 | 10:32 PM
Hawk2010's Avatar
Hello, I have a 97 f150 with the 4.6 v8. The bolt on the exhaust manifold the connects to the y pipe broke. There is a chunk missing where the stud was. .My question, what are the odds of getting manifold off without breaking manifold bolts off in head? The bolts look pretty weak. Thanks for any input.
Old Feb 25, 2010 | 10:36 PM
avfrog's Avatar
Breaking bolts seam to be a common problem with these beast...
Old Feb 26, 2010 | 12:32 AM
Takes alot of patience, ease, and penetration grease to carefully get a stud out un broken. This isn't just with Ford though, many bolts crap out over the years due to all of the heat the engine puts out, rust and salt, and the manufacturers for putting cheap bolts in. Replace with stage 8 bolts after wards and you will never have the problem again, and if you buy a brand new truck, go with stage 8s asap and prevent the problem in the future.
Old Feb 26, 2010 | 02:42 PM
goosegunner's Avatar
My 97 expedition has some broke manifold bolts. The Mechanic says We should replace manifolds also because they are usually warped. Is there something better I should put on besides OEM?
What about the stage 8 studs, Where do you get them?
gg
Old Feb 26, 2010 | 06:39 PM
avfrog's Avatar
^ Grade 8 bolts...
Old Feb 26, 2010 | 09:45 PM
Originally Posted by avfrog
^ Grade 8 bolts...
My bad.
gg
Ford Racing offers a set. Usually replacing with shorty headers is good rather than the same stock manifolds, if you dont want to add in longtube headers.
Old Feb 28, 2010 | 09:36 PM
Started a new thread
https://www.f150online.com/forums/ex...t-replace.html
gg
