no muffler vs. muffler
Old Feb 23, 2010 | 08:24 PM
avfrog's Avatar
^ ha ha We may argue back and forth a time or two, but we mean well.
Old Feb 23, 2010 | 09:59 PM
mav015's Avatar
my way cost me 12 bucks
Old Feb 23, 2010 | 10:48 PM
Originally Posted by tboy12
yes. si/do flowmaster. it is super quiet and i dont know why. i bought it off a guy on here and theres nothing wrong with it but im not real sure which model it is. its just wayyy ttoooo quiet.
All actual Flowmaster mufflers have a part # etched in the the of the inlet, or outlet wall. Find it, write it, and check it on summit. My guess is its a 50 series if its 18"s long. If not, then you have a high thirst for volume.
Old Feb 23, 2010 | 11:16 PM
RAF150's Avatar
Originally Posted by 4.6 Punisher
Well it's a SIDO and you have stock cats. Just swap the muffler out with a Y-pipe and you can have your straight-pipe sound and still retain your torque.
Sorry still trying to understand your comments. Are you implying that dumping right under the cab will yield less torque than dumping to the rear of the truck? Are you implying this due to back pressue issues??
Old Feb 23, 2010 | 11:24 PM
avfrog's Avatar
^ 2 into 1 at the factory y pipe, then y pipe into your tails in front of the axle. Dumped compared to running tips will have absolutely ZERO effect on power! Don't let anyone tell you other wise.
Old Feb 23, 2010 | 11:30 PM
RAF150's Avatar
Exactly.
Old Feb 23, 2010 | 11:36 PM
4.6 Punisher's Avatar
It's the same concept as running open headers. Velocity is lost and power is lost.
Old Feb 23, 2010 | 11:42 PM
RAF150's Avatar
No it's not. Running straight headers is way different than dumping under the cab after all the cats. The amount of back preassure lost opening up after the cats is minimal.
Old Feb 23, 2010 | 11:52 PM
When you use terms like "back pressure" and "opening up", you lose a lot of credibility.
Old Feb 23, 2010 | 11:59 PM
RAF150's Avatar
Sorry I'm not using the best technical terms for you. Instead of questioning my credibility why don't you explain your reasoning in more detail so everyone can understand why.
...but if not, i'm over it.
Old Feb 24, 2010 | 12:35 PM
It's like running open headers. The shorter you exhaust is, the more velocity is lost, the more power is lost. These engines aren't designed to run a short exhaust, which is why performance is lost when you dump it right after the Y-pipe. But if you don't believe me then that fine. I guess you're calling the OP a liar, and countless other people that have reported low end torque loss after dumping their exhaust.
Old Feb 24, 2010 | 12:38 PM
RAF150's Avatar
Liar? Don't think I said that. Thanks for your explanation.
Old Feb 24, 2010 | 12:41 PM
No problem Mr. Back-Pressure.
Old Feb 24, 2010 | 12:51 PM
RAF150's Avatar
Haha, it’s ok calm down bud. No need to get your exhaust panties in an uproar. Everyone's just trying to learn here.
