straight pipes
You wont lose anything noticeable unless you calculate every sip of fuel on mpg tests. You will not be able to pass in an emissions county, or at a place where your not good friends with the inspector.
i cut mine off and havnt seemed to lose anything.
but the cold weather has taken a toll . it is some how effecting back pressure causing system to lean codes then inturn putting more gas in to the cylinders
so if ur doing it for the short term just to get some sound until u have enough money to get a new exhaust go for it but long term is not a good idea.
Or by the "just run straight pipes" comment are you looking to add duel exhaust of some form?
I did not notice any gas mileage loss from my true duel set up. I wouldn't think you would lose mileage period.
As for VA inspection. A muffler does nothing, that I know of, for emissions. So you would be fine that way. If they require that everything has a muffler you would be screwed.
Are you just wanting to cut the muffler out and add pipe to fill the space on your stock exhaust?
slow as in redneck sounding most likely. Typical small stabs. Whats funny is no muffler, and straight through mufflers, perform the same way, and straight through mufflers are best for performance so...
ha i would say it sounds like it's going fast not slow.
well probably i didnt explain it well enough it sounds good no lie but sounds like it is under a heavy load for no reason ALL THE TIME, and yeah i own a truck so i wudnt forget wut a real truck should like, its gotta sound like it has ***** not like a dying tortoise
