i need help
Old Aug 7, 2009 | 02:25 AM
fx4f1507's Avatar
Exclamation i need help
my truck has been getting trouble codes the past couple days saying bank1 and 2 running to lean. i have a kandn intake and edge evo. i have had them both for a few months and im just now getting trouble codes. what should i do? i dont want to cause any more problems by keep driving it like this.
Old Aug 7, 2009 | 02:35 AM
its the intake, 3v 5.4Ls especially 04s and 05s cant handle CAIs without custom tunes for it.
Old Aug 7, 2009 | 10:14 AM
4.6 Punisher's Avatar
Yep, you're running so lean that you can actually plan a date for the engine detonating. Remove the cold air intake and don't put it back on until you get custom tunes for it.
Old Aug 7, 2009 | 01:30 PM
fx4f1507's Avatar
ok thanks what kind of custom tunes should i get
Old Aug 7, 2009 | 02:30 PM
bigdog87's Avatar
Personally, PHP Gryphon.
Think theirs really only two options, the Gryphon or an Xcal
Old Aug 7, 2009 | 03:51 PM
The Gryphon is an excellent programmer with custom filed tunes if you request, or the Troyer Xcal tunes.
Old Aug 8, 2009 | 04:47 PM
kakings's Avatar
I'm having performance issues with my truck. When I accelerate, it sometimes seems to respond for a split second then kicks into an almost no response mode. I'm pressing the throttle and it's barely getting any RPM's and when the RPM's do get up, the tranny does not shift normally. I've replaced cats and throttle position sensor to no avail. In the past I also got a few lean bank codes but was told to clean the MAF sensor and it seemed to work. I've seen another post complaining of the same response issue and now I'm seeing this code post. We all seem to have the same thing in common......K&N air intakes. I'm wondering if that's the issue, since my problem only started after the intake was installed. I'm running an '01 Harley and wondering if the same issue is surrounding it as the 03 and 04 models as was stated in the earlier post? I need help!!!
