Just did my exhaust, not loud enough!!!
I have the 99 f150 4.6L V8 4X4, Airaid intake, granatelli tuned MAF, Edge Evo tuner.
I just did a stainless 2.5" true dual Exhaust, Xpiped with two 11" Magnaflow 2.5" SI/S, with the tips 45 degrees behind the rear tires..
Iv read that these will break in and become louder? if so how long?
I orderd my JBA ceramic shorty headers will this make it louder or should i change to magnaflow high flow cats?
x2 on that!
As for my headers they show up tomorw cant cancel.... any idea wat my options are for cat? i was thinking of deleting the rear cat and doing magnaflow primaries? any idea wat the part # is?
Delete all the OEM cats for just 2 Magnaflow hi-flows, Darren will chime in with the part number. I guess the shorties will have to do, anything is better then the stockers. FYI this setup will make your truck sound damn near like a Mustang GT, so just a heads up.
You shouldn't but if you do get a CEL its easy to fix. Your rear O2 sensor should be after your rear cat, if its mounted in it like some models have it, you will need to re-mount it in the pipe, then do the O2 mod.
