True Duels Installed
Old May 16, 2009 | 09:35 PM
Mamay's Avatar
Got true duels today: 14" oval magnaflows with a magnaflow x-pipe and 4"x18" tips 45ed off the back. I cant be happier. I cant keep my foot off the skinny peddle. Starts up really nice. Then has a quite deep tone at idle. And on take off sounds like a bat out of hell.
Thanks everyone on here for all the help.
Just got one more question. Would a CAI make a difference. I have an 03 SCREW with 63,000 miles. I cant get a gryphon for my year. That was the programmer I liked most. Is a CAI still worth it?
Old May 17, 2009 | 12:04 AM
LOHfootball53's Avatar
I don't know the CAI answer, but what size piping did you go with? I want to run almost the same setup, but with 2 cats instead of 4. Any low end torque loss?
Old May 17, 2009 | 12:25 AM
Congrats, enjoy. a CAI would help the note be a little stronger, and performance would increase a little, even better with an intake.
Old May 17, 2009 | 12:30 AM
bigdog87's Avatar
I'm down! x2
Old May 17, 2009 | 02:03 AM
migdaddy's Avatar
ya get that intake..itll be a little throatier..any vids??
Old May 17, 2009 | 08:51 AM
openclasspro#11's Avatar
as long as he ran 2.25"[especially if he has a 4.6],and kept x as close to original y location as possible
Old May 17, 2009 | 09:46 AM
how much would i lose if i went with 2.5"?
Old May 17, 2009 | 09:53 AM
is it a 4.6 or 5.4,i went with 2.25" on my 5.4 and gained SIGNIFICANTLY over my 3"siso oem setup on my 04 superduty in the lowend area...
Old May 17, 2009 | 09:56 AM
its a 5.4
Old May 17, 2009 | 12:19 PM
if you use your truck -not drag racing it-by this i mean driving it normal-using the tq that the triton provides, 2.25" is the way to go- now the 2.5 will deliver a tad more in top in hp in the upper rpms, but it loses in the tq dept. under 3500 to the 2.25"
Old May 17, 2009 | 01:01 PM
alright....thanks...well since i already have a 2.5" muffler i am re using, i probably will go with 2.5 true duals. i do not tow alot so i think i will be fine. thanks for the help openclass.
Old May 17, 2009 | 01:20 PM
i assume you are using a 2.5" dido muffler?you could still use 2.25 in /out,they would just expand the 2.25" by swedging it to mate the 2.5" muffler,consider this -even though you do not tow-you still do not want to lose any bottom end,these 6000 lb trucks need all the bottom end they can get, imho-anytime i can help bro-phil
Old May 17, 2009 | 03:12 PM
no...i have a si/so 4x9x14. i would get another one and an x pipe to run true duals along with either 2 high flows or just deleting my rear cats.
Old May 17, 2009 | 03:21 PM
You can still use 2.25" pipes with the 2.5" mufflers.
Old May 17, 2009 | 03:40 PM
4.6 Punisher's Avatar
Did you use mandrel bent pipes or those god awful crush bent pipes?
