True Duels Installed
Old May 17, 2009 | 04:35 PM
LOHfootball53's Avatar
You can still use 2.25" pipes with the 2.5" mufflers.
i know...but i dont want to lose volume like some people have said comes with 2.25. btw, how much torque did you lose?
Old May 17, 2009 | 07:40 PM
openclasspro#11's Avatar
x2
correct a mundo fonzarelli
Old May 17, 2009 | 08:49 PM
so go with 2.25 pipe and the 2.5 mufflers.
Old May 17, 2009 | 09:31 PM
yes,the 2.5" mufflers will be the pressure reducing zone, once the gases pass through them and re-enter the 2.25" tubing,your vp will go up hence affecting your tp ,the bottom line your tq will go up,use mandrell bent pipe,also ss is preferred -most feel anti corrosion in the salt belt is the main reason for using it, the main reason is the heat holding capability of it -hence increasing exhaust gas scavenging...
Old May 17, 2009 | 09:45 PM
gotcha. thanks for the info man.
Old May 17, 2009 | 11:28 PM
I dont know exact numbers, but my truck doesn't like pulling 6,000lbs much anymore. Unloaded and WOT it moves, but regular cruising ( 4th gear, OD ) it takes awhile to gain speed, even tuned.
Old May 18, 2009 | 02:39 PM
4.6 Punisher's Avatar
Sooooooo for maximum torque use 2.25 pipes, 2.5 mufflers and 2.5 X-pipe?
Old May 18, 2009 | 02:46 PM
no, keep everything 2.25", but if you already have 2.5" parts you can make them work. Its always best to stay 1 full size on both banks.
Old May 18, 2009 | 02:58 PM
That's what I was thinking. Disrupting the flow from small to big several times can't be good for escaping exhaust gases.
Old May 18, 2009 | 03:16 PM
precisely why crimp bent pipes suck.
Old May 18, 2009 | 05:50 PM
what darren said- 2.25" pipes into 2.25" x pipe,expanded to mate into inlet of 2.5" mufflers,have 2.25" tailpipes expanded to fit over 2.5" muffler outlets,i cannot be any simpler than that
Old May 18, 2009 | 06:52 PM
alrighty....thanks y'all
