Long Tube Header Install Help
Old Apr 30, 2009 | 11:17 PM
BLUEBEAST06FX4's Avatar
When I replace my stock headers with a set of long tube after market headers will I have to move any parts of my exhaust around such as the cats? If anyone knows what the exact process is the advice would be helpful
Old May 1, 2009 | 12:30 AM
Your going to need to get hi-flow cats because the stock cats wont last very long with the heat and force of longtubes. If you dont have any to swap to, then you could probably rig the stock ones to work since you have the two cat system.
Old May 1, 2009 | 06:47 AM
bluebeast06's Avatar
yea you have to move them the long tube are way longer, nice name by the way, way to be origanal
Old May 1, 2009 | 04:37 PM
05crewzer's Avatar
dynatechs come with everything to install. some you will have to use shorter cats because of the longer tubes and collecters. it depends on the brand you go with. pick your headers and advice will follow.
Old May 2, 2009 | 04:18 PM
what kind of headers do you have? I saw your pics... How much were they?
Did you install yourself?
Old May 2, 2009 | 06:14 PM
i have pace setters, bought them from summit they were 3something i forget the amount look them up. yes i installed them my self, i have noticed mine are hitting the frame only when i put the truck in reverse so if i could do it again witch i might go with dynatech they come with cats and everything.
Old Mar 26, 2011 | 08:44 PM
Mwood1986's Avatar
Hate to bring this thread back to life but not many people have installed long tube headers on these trucks. I was wondering how difficult the install was? Besides the normal rusty stuck bolts n stuff.
I'm assuming you have to drop them in from the top but do I need a cherry picker or am I able to slip them in with regular tools?
Old Mar 26, 2011 | 08:53 PM
04wes97's Avatar
I'm putting on a set of pacesetter's long tubes tomorrow. i'll tell you every headache that i come across sometime soon.
Old Mar 27, 2011 | 02:31 AM
batn68's Avatar
I went in underneath, drivers side is cake, passenger side will give you some fits.
Old Mar 27, 2011 | 08:39 AM
04wes97's Avatar
batn68, when you did yours. did you have to loosen the transmission and motor and everything like the directions say? removing the starter and stuff i know is going to have to be done. but that seemed like a little bit of overkill, i just wanna know what to expect. i'm going to do my install here in a few hours.
Old Mar 27, 2011 | 09:28 AM
mikeyss's Avatar
I put a set of pacesetter long tubes on my 2000 Harley F150 2wd. I removed the inner fender liners to get a clear shot. The only think I had to remove was the oil dipstick tube, and of course the original 4 cat setup. I installed both side headers from under the truck, I didn't have too much trouble. One important note, once you remove the original exhaust manifolds and studs, thread chase all of the holes - it makes starting the header bolts much easier and you won't cross thread. It is VERY easy to cross thread the header bolts because the heads are soft aluminum. All this work is very much worth it, you'll love the top end that long tubes give you
Old Mar 27, 2011 | 09:54 AM
batn68's Avatar
I think you lifted guys have an advantage over us 2wd guys. I did have to remove the starter and remove the pass. side motor mount so I could jack the engine up an inch, did not touch the tranny, not sure if the 4wd guys have to jack anything up. The thread chasing that mikeyss advises I would do that, I didn't and I did cross thread my last bolt, it was way easy to do. There will be some cussing, especially on that pass. side if u don't have some stubby wrenches, I know I sure did...
Old Mar 27, 2011 | 05:11 PM
The Real Mccloy's Avatar
Hi,
I put a set of OBX's complete with y-pipe and resonators on a year ago on my 06 4x4, removed inner fenders, manifold studs, and jacked up pass side motor mount. I had no problem getting the pass header in without removing the starter, the PITA was getting the bottom bolts started, probably took me 3 hrs just to get the bolts in and tight.
Old Mar 27, 2011 | 11:44 PM
04wes97's Avatar
i just came home from doing long tubes on my 04. i expected a headache, and it was. the starter did have to come off, motor jacked up, didn't touch the tranny though. if you know what your getting into it wasn't that bad. i had one huge set back though. when removing the dipstick, the bottom half broke off down in the motor. so had to drop the pan and get it out. along with a 45 dollar oil change...damn it. but the headers themselves....just expect it to be a pain, and you won't be disappointed. very worth the work.
Old Mar 29, 2011 | 07:44 PM
Mwood1986's Avatar
Thanks for the info guys I appreciate it. Thinkin I'll just wait till I have a garage to do it in just in case something does go wrong.
