True Duals W/ low end
Old Mar 22, 2009 | 04:33 PM
  #31
jakek88's Avatar
While stock? Thats actually impressive, was the Chevy 'trying'? GM trucks are a few pounds lighter and are programmed much better than Fords are. Ford tuning contains alot of lags, I have never seen an all stock F150 whoop an all stock GM truck of our generation, or even the previous generatiobn '97 - '03. I dont race my truck but ever since I got my Gryphon my GM buddies are very impressed with the harder pull my truck has now but the fact of the matter is, the truck is still about 5400lbs.
yea, it was a 5.3L in a chevy 2500 pickup. that truck has a little more weight to lug around.
Old Mar 22, 2009 | 06:40 PM
  #32
Ah. I dont believe GM ever put the 5.3 in a 2500, but I dont know for sure. Usually it was always the 6.0L because the 2500 was the same as a 1500HD. I used to have an '05 2500HD so i'm pretty knowledged with the GM trucks.
Old Mar 22, 2009 | 09:01 PM
  #33
yeah I'll have to agree with Darren, I'm pretty good with the engine sizes, the only 5L range engine i can recall in the more recent 2500's is the 5.7, which was in the 2000's and under. It is now the 6.0 and other than that, the 8.1L V8 which was their higher powered engine.
Old Mar 22, 2009 | 10:06 PM
  #34
jakek88's Avatar
my bad guys, the truck belongs to a friend of mine and its a 2003 1500hd i think. its a half ton with heavyduty suspention
Old Mar 23, 2009 | 12:27 AM
  #35
birddog_61's Avatar
The 5.3 is slow, I take my buddies 08 1500 from a stop all the way until his speed limiter and I am pulling away the whole time.
Old Mar 23, 2009 | 02:45 AM
  #36
RoushF150's Avatar
You will gain low end when supercharged for sure. You will not gain or lose low-end on these engines if you are n/a because the placement of the y-pipe is so far away from the engine scavenging affects are limited.
You will lose torque if you change the headers out and not supercharge.
Old Mar 23, 2009 | 11:41 AM
  #37
MudTerrain's Avatar
I've seen it before. Nothing new around these parts.
Old Mar 23, 2009 | 01:00 PM
  #38
TXDREW's Avatar
This sounds awesome, and I'm thinking about doing it to my truck. Is this illegal to run this without a muffler, or is the X pipe considered to be your muffler?
