New Magnaflow duel or single???
Can't decide what to do.
current setup stock exhaust with flowmaster 44 dumped
99 4.6 2wd
(2 magnaflow 94106 hi flows)
should I remove all four or leave the front 2.
Then I'm not sure
1....True duel with and x pipe and 2 si/so 14" magnaflow to 2 1/2 in rear exit.
2....si/do magnaflow 2 1/2 in rear exit.
3....si/so 3 in magnaflow dumped at axle.
Thanks Matt.
99 4.6 2wd
Then I'm not sure
Thanks Matt.
I was wondering the same question but I didn't really want the duals, so.....thanks to some advice from Darren, I'm going to run 3" all the way back...from the cats to a SI/SO Magnaflow and back behind the tire.
But, lately, I have been thinking about dumping it....i.e. your #3 choice.
I would suggest to you the full 3" system like ShadowSTX is going with for best performance, but if you want that true dual sound the duals will sound good, go with an X pipe if you do. And if you do want it quite loud go with the 11" body mufflers. My truck is running pre-cats only and 11" body true duals X'ed and its as loud as a Chevy with a Flowmaster.
If your inspection station will allow you to remove all cats to be replaced with two Magnaflow converters go for it. Otherwise you may be best off with the pre-cats left alone then the hi-flows. The rears are what really kill the volume and flow.
Eliminates? Sorry man but that is very false. An X pipe helps balance the scavenging to be 50/50 for both banks. The passenger bank is usually stronger due to its shorter length and bends ( left bank true dual is usually 3.5' longer than the passenger! ) so the left bank will make the engine dog out a little when unbalanced forcing it to work harder, which will cause it to run a little lean, not to mention drink down the gas more. The X pipe 50/50 balances by jointing the banks together in a 4" center section and them flows out through the exhaust. Another plus to the X pipe is it balances the sound out much better because un-balanced the left bank will usually be much quieter than the right bank.
Yea I know for sure run an x pipe for true duel.
I also found this from summit racing.
PSM-82-1153
3 in y pipe goes form cats to muffler.
so pre cats stay in, then hi flows.
should I go
pre cat, 2.5 in hi flows, adapter then the 3 in Y.
or pre cat, 2.5 adapter to 3 in hi flows to 3 in Y.
with that then 3in si/so dumped.
or maybe 3in si/do 2.5 dumped then i could always put tailpipes on to quite it down if needed. Man decisions decisions.
PSM-82-1153
should I go
PSM-82-1153
should I go
PSM-82-1153
should I go
Im just concerned if I switch from 2.5" from the y pipe to 3" I might ******* up something, especially without a tune.
What I was thinking is that keep the 2.5" and have a dual exhaust... same pipe used for the cats... and then out back.
I heard an H pipe is good for us 4.6L engines..?
