Question about high flow cats
Old Feb 10, 2009 | 10:43 PM
  #31
No problem man. Very normal, you may be able to smell the exhaust a little on cold starts from now on, and it might smell like hot metal for awhile. All will be good, shouldn't ever get a CEL if the sensor was factory mounted after the cat.
Old Feb 11, 2009 | 10:20 AM
  #32
4wd150's Avatar
will it still pass the sniffer?
Old Feb 11, 2009 | 10:34 AM
  #33
Hopefully. But if your exhaust shop did the job it must be fine and legal. You had all 4 replaced with 2 hi-flows right?
Old Feb 11, 2009 | 02:46 PM
  #34
4wd150's Avatar
yeah. 94306 were the cat numbers. ergh everyones still saying to me my truck sounds the same. how is that possible?
and also, i called Magnaflow about the smell, he said that since i had the shop mendrel bend new pipe before high flow cats, he says the oil they use is just burning off and something with what the cats are coated in.
Old Feb 12, 2009 | 01:00 AM
  #35
Cause Flowmaster is loud to begin with, and no one will know your trucks sound or behavior better than you.
& thats true.
Old Feb 12, 2009 | 10:07 AM
  #36
4wd150's Avatar
true
