Why does the stock intake take the air from above the wheel well
Originally Posted by joshmac4.6
To prevent it from pulling hot air out of the engine compartment
Is the hot air bad??
Also, while we are on the subject, has anyone ever re-routed the air intake to force more air in? Like ram air? I did a similiar mod on my old Alero and surprisingly, it helped with flow.
Isn't cold air denser, which is how you achieve more oxygen for the combustion process? I do believe denser. Wow... why can't i remember these things? But yeah, the cooler air provides more molecules, and you get a cleaner, more efficient burn, which produces more power. So in theory, every degree lowered would yield better results. But if you check intake air temps, they don't change as much as you would think with a "cold" air intake. The power is usually more a result of higher flow combined with slightly cooler temps. Correct me here if im wrong guys, but using an Edge and charting IAT, the difference wasn't huge.
