OBX longtube dyno results....
Old Mar 12, 2008 | 10:39 PM
  #31
01Roush's Avatar
Originally Posted by joshmac4.6
I want to hear it!!
You can find links in my install thread.
Old Mar 12, 2008 | 10:50 PM
  #32
Folmar150's Avatar
I agree with you jackal.... i'd be happy with 25/30 on my 4.6 as well.
Would you guys say a custom tune by mike or whom ever would yield close to the same results as a dyno tune?
BTW how easy is everyones rusty manifolds coming off? I mean mine have been on for 9 years and they dont look pretty. Just curious so see how everyone made out with removal.
Old Mar 12, 2008 | 10:55 PM
  #33
joshmac4.6's Avatar
Dyno tune will outperform any non-dyno custom tune, PERIOD!
Old Mar 12, 2008 | 10:57 PM
  #34
built54's Avatar
My tune was done on the street, with my tuner in the passenger seat with his laptop, tuning as I drive. Its the only way to do it when your working with a whole new setup.
Old Mar 12, 2008 | 10:59 PM
  #35
joshmac4.6's Avatar
Ok forgot to add live tuning as well, my bad, but to really get the best num's the dyno is needed. I have a pretty well calibrated but dyno, but an extra 3-5hp is not detectable by my cheeks.
Old Mar 12, 2008 | 11:03 PM
  #36
jbrew's Avatar
I just give it a fresh "boot" for a new tune
Old Mar 12, 2008 | 11:29 PM
  #37
01Roush's Avatar
Yep, especially for the part throttle and drivability stuff street tuning works great, unless you have a load bearing dyno and can spend extensive time on it. That normally isn't practical for numerous reasons. WOT is better on the street than a Dynojet too, just often isn't practical because of the speed required. A Dynojet drum only provides loading to the equivalent of something like a 2500lb vehicle, so the load is way off when dealing with 5000+ lb trucks. Not much trouble when n/a, gotta be accounted for with blowers & turbos....
Old Mar 13, 2008 | 03:31 AM
  #38
shifty_85's Avatar
i took mine off my 97 4.6L after 10 years...Michigan winters and salt No probs... the Nuts were so rusty that they locked and pulled the nut-stud out at the same time!!! i got lucky i guess didnt break any! after i finished with one side i noticed hey these are nuts on a stud holy crap! haha.
See Jbrew No wonder i dont feel a power loss with my 3" pipeing because the LT's gave it so much more TQ. However we will see when i get some more money to get my truck dyno tuned... Im going to have them put my shorty numbers in for a baseline to go VS my LT's Then i will say go at it for an hour guys and tune it up!! Then ill do all 3 on one sheet if they can do that... Shorty numbers LTs*No tune* LTs*tune*....just need to find that 400.00 dollars i left layin around.....
Old Mar 13, 2008 | 05:45 AM
  #39
jbrew's Avatar
Yea, yea - you might have a little top end with that set up, but by the time you find it , I'll all ready be at the Finish Line - Looking for yuh
Shifty , look at the Dyno graphs 01Roush posted. Look @ his torque lines - compare them to yours. See how even and high those numbers are compared to yours ? Look at the rpms . He has torque across the graph in the lower rpms, that's how it should be. In your graph you make torque finally @ 4100 rpms. Your graph is BEFORE you added Long Tubes and 3" piping all the way out. When you go run it again with the mods you have now , it will be worse. Sure, you'll most likely have a higher MAX torque and HP , but it's going to take longer getting there because theres nothing behind the headers to take advantage of them.
Old Mar 13, 2008 | 08:37 AM
  #40
built54's Avatar
Yea that, and there is no way to get your shift timing and pressure tuned on a dyno
Old Mar 13, 2008 | 11:15 AM
  #41
joshmac4.6's Avatar
The big torque diff. is mainly due to the longer stroke of Roush's 5.4 compared to shiftys' 4.6L as well.
Old Mar 13, 2008 | 11:34 AM
  #42
jbrew's Avatar
No sh^t !! I thought he had a 4six - I looked around , it was a biatch to find a post with his motor size . It's not in his sig , or his info. - I finally found a post where it says he has a 5four.
I thought he had a 4six - no wonder his headers went on so easy and numbers are so good
My bad .
Old Mar 13, 2008 | 11:42 AM
  #43
joshmac4.6's Avatar
Woah , the torque curves were being compared, It seemed a good thing to add. The 5.4 makes alot more torque down low than its little brother. I was just putting out there that the CID makes a diff. in the ''Powerband". My bad:o
Old Mar 13, 2008 | 12:26 PM
  #44
BSL's Avatar
BSL
this was on a 4.6L right? will the gains be the same or better on a 5.4L? I'd be more than happy with his gains but if they were more I'd be stoked also
Old Mar 13, 2008 | 12:31 PM
  #45
joshmac4.6's Avatar
This was on a 5.4L.
