K&N or AEM
Old Dec 21, 2006 | 02:31 PM
  #31
Jordan not Mike's Avatar
DeathMetalTruck,
I see what you are saying but dynos aren't representative of actual on-road conditions either.
While it is true that a closed hood will result in increased underhood temps on a truck that isn't moving, there have been several members on this site and others that put temp probes under their hoods to measure the temps on the road.
The results:
When the vehicle is not moving, underhood temps do rise.
When the vehicle is moving, though, enough fresh outside air is forced underhood that the temps are just a little bit above ambient.
Old Dec 21, 2006 | 02:51 PM
  #32
DeathMetalTruck's Avatar
Yeah I def see what your saying there. Makes sense. Either way all my point really was is that I don't think your gonna get nearly as much gains as any of these companies claim.
Old Dec 21, 2006 | 02:55 PM
  #33
04 F-150's Avatar
I installed my AF1 it was very simple, did not even need to unplug the battery and none of the warning lights ever came on
Old Jan 4, 2007 | 01:10 AM
  #34
FX4life's Avatar
This k&n doesnt show a heat sheild, i suspect it does come w/ one. all my searching has yeilded little results it always brings up everything w/ CAI or cold air intake in it as well as k&n Im thinking this is the intake most ppl are talking about when they say 77 series, correct me though if im wrong.
http://store.summitracing.com/partde...1+4294906144+0
Old Jan 4, 2007 | 05:27 PM
  #35
hillman's Avatar
theres one without the heat shield and one with the heat shield. make sure youre getting the one you want. i got the one without the heat shield.
Old Jan 6, 2007 | 01:50 AM
  #36
bshipley78's Avatar
Thumbs up I Say AEM Brute Force
I would go with the AEM Brute Force, I found it at autoanything.com for $296 but input GIFT10 in the coupon slot and you get it for $267.25 free S&H
I have always been a fan of K&N but through my research I have found that the AEM will produce better results. Either way I'm sure you'll be pleased.
Old Jan 7, 2007 | 10:32 AM
  #37
josho66's Avatar
Originally Posted by swwaltw
Troyer's web site says the airforce one is the best
They also say the Airaid is the only other intake that does not cause a lean condition with the engine.
Old Jan 9, 2007 | 08:01 PM
  #38
Aaron Morant's Avatar
If I had to choose between K&N or AEM, I would choose the AEM.
Bang for the buck = Outlaw Power
