Rattle rattle thunder clatter boom boom boom?
Old May 27, 2006 | 01:49 AM
Zaairman's Avatar
Question Rattle rattle thunder clatter boom boom boom?
Ok, not really all of that, but a rattling sound. It's coming from the exhaust somewhere, at a low RPM (under 2K) when the motor is under a load, like pulling the boat or turning out of my driveway up the hill. Any ideas? It sounds as if it's coming from the back, but I'm not positive.
Old May 27, 2006 | 02:35 PM
smkeater's Avatar
loose clamp? Happened to me when at low rpm and truning the damn pipes seemed to have a metal reverb or clanking. Had the clamps dogged down and tach welded the nuts no problem ever since
Old May 27, 2006 | 02:37 PM
Zaairman's Avatar
The exhaust is fully welded, it is aftermarket.
Old May 27, 2006 | 02:48 PM
smkeater's Avatar
Couple options to check: Check your space where you tails exit make sure they dont hit the bumper, check all your hanger make sure none have dropped out of place or the welds cracked as well as your clamps, anything near your pipes tire! leaf springs! axle! Just a thought here tryin to help narrow ideas. Which way do you turn? I know you mentioned yours is fully welded but check your welds, I had one bad clamp and weld and it rattled like a #$@%$. JUst my .02
Old May 27, 2006 | 02:57 PM
Zaairman's Avatar
Awww man, you want me to go outside don't you. It's only a nice 96 degrees out. I'm thinking it could be a loose hangar, which is causing one of the tips to rub against the hitch....I think....
Old May 27, 2006 | 03:03 PM
Zaairman's Avatar
Damn... I just went out and looked at it, and the welds on tailpipe hangar on the pass side broke off
Old May 27, 2006 | 03:05 PM
smkeater's Avatar
O stop whats a little heat . Its 85 here to bad my pool isnt warm enough. anyway that whatim actually thinking it might be a hanger, they dont last to long Good Luck hope I helped
Old May 27, 2006 | 03:10 PM
Zaairman's Avatar
Yeah, it was kinda cool under the truck. KINDA. As in, lowest temp of hell. But yeah, it's the hangar. Guess I'll have to call up the exhaust shop and see what they can do.
Old Jun 2, 2006 | 08:06 AM
smkeater's Avatar
How did you make out with the hanger?
Old Jun 2, 2006 | 08:32 PM
Zaairman's Avatar
Took it to the shop, and they reweled it for free.
