Broken oil dipstick
Take a few bread ties and wrap them very tightly around a small piece of rag and stuff it down the dipstick tube hole. This will keep debris out of the oilpan, and you can pull it out with the bread tie after you get finished with it. Take a small chisel and a hammer and cut a gap in the remaining piece of the dipstick tube and take a small screwdriver and pry it out. Now you have the broken piece out. Just pull the rag out when you get done with the bread tie that's wrapped around it. Job done!
on
1 Post
Originally Posted by Ronsbusa
The piece is still in the hole. Not sure if I should drill it out.
do not drill anything that will put metal chips in the pan whatsoever!!!...slow but constant engine death will happen...can you get to where the dipstick tube goes into the pan?or block?...see if you can get the tube out of the boss...the 'stick will come with it...zap!
