overdrive light flashes
Old Apr 16, 2002 | 02:39 PM
gina and scott's Avatar
can anyone explain to us why the overdrive light on our 1997 F150 is flashing. we can not find anyone who knows. if you can help please e-mail us at gmcutie@hotmail.com. thanks
Old Apr 16, 2002 | 03:05 PM
AjRagno's Avatar
If it's flashing, there is something wrong with the transmission.
Similar to a Check Engine Light but this one is for the tranny.
If you take it to a dealer, they can scan the computer.
Old Apr 16, 2002 | 04:09 PM
we have taken it to a transmission place and they said its not the transmission.
Old Apr 16, 2002 | 04:32 PM
max mitchell's Avatar
gina and scott-
If your transmission shop doesn't know what Aj mentioned, go to a reputable dealer. Try a Ford dealership.
Old Apr 16, 2002 | 04:59 PM
the truck is running in limp mode. not sure if this will help anyone give us advice,but i hope. thanks
Old Apr 16, 2002 | 10:28 PM
hmustang's Avatar
There is something wrong with the tranny if you are having problems like if there are no shifting problems then it would be the wires in the shifter its self.
Old Apr 17, 2002 | 07:40 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
The F150 automatic transmission has about eleven sensors on it. The sensors cause good things to happen. When a sensor fails the good thing it caused doesn't happen anymore and the OD light blinks to let you know there is a problem.
Sensors can fail intermittently, this can be very frustrating when the OD light doesn't blink at the dealership but, does when your down the road. If this is the case, Ford can lend you a 'flight recorder' which will give you the ability to trap the code necessary to identify the problem.
A sensor itself only costs 30-60 dollars but, you can't just pick it up at the parts counter, it has to be programmed then installed still, this is usually less than $200.
A blinking OD light, left to just blink could lead to a $2,000 transmission.
Good Luck,
Old Apr 17, 2002 | 06:01 PM
hmustang's Avatar
So as Raoul says pay a little now or alot latter.
Old Apr 18, 2002 | 12:59 AM
AjRagno's Avatar
Thumbs up ROTFLMAO for the first time in my life!!!
Raoul oozes with mechanical insight
Neato!!!
Old Apr 18, 2002 | 08:19 AM
Raoul's Avatar
25 Year Member
Smile
Aj, I usually don't break it down like that but, the User Name said, 'gina and scott' and for some reason I pictured them sharing a chair, each with their own half of the keyboard.
I got the feeling that scott could type all he wanted to but, gina had control of the mouse.
Old Apr 19, 2002 | 07:21 PM
Talking fixed
just wanted to tell everyone that we got the truck fixed. and since the truck has 40" tires and is lifted there was a wire under the truck somewhere(sorry i'm not sure where) that was worn out because of the lift. it was stretched out. thanks to everyone for your help and suggestions.
Old Apr 20, 2002 | 12:02 AM
AjRagno's Avatar
Thumbs up Good to know!!!
Don't be strangers, you 2 There's a lot more info where that came from.
Ufta!!!40" tires!!! Sure wish I had 40 inches......
