Linkswell Gen 2
Old Jan 5, 2022 | 04:59 PM
Bolsinger4746's Avatar
Linkswell Gen 2
Is anyone else having issues with their linkswell Gen 2 or linkswell t style radio in general with low power output? I have asked multiple people to include linkswell themselves they don't know how to fix this issue, has anyone else found a go around for this issue?
Old Jan 5, 2022 | 09:40 PM
I think you need to explain what low power output is. You mean low power output to the speakers?
Old Jan 6, 2022 | 08:27 AM
No. Low power output as in the USB ports have less then ampel power to charge any device. Plug in my phone at 80% and it says 3 hrs or more to charge full. If screen is left on and using hands free it will drain phone very fast.
Old Jan 6, 2022 | 10:32 AM
Try a USB cable that is known to work to charge your phone, not all cables will charge. It's also very possible that the port *IS* low power and is not designed for charging. If it has more than one port, try the others.
Old Jan 6, 2022 | 11:19 AM
I have 3 ports. I tried all and all low voltage. Also, the cable will charge perfectly with a wall adapter or batt pack.
Old Jan 6, 2022 | 03:51 PM
Sounds to me like the unit itself is not designed for charging.
USB is 5 volts by definition. Do you mean low *amperage*?
Old Jan 6, 2022 | 03:53 PM
Low something. It will not charge. It has enough power to hold current charge on a device when not being used, but once you use said device it's as if the device is not charging.
Old Jan 6, 2022 | 05:22 PM
That's typical of data ports that are not designed for charging. USB 2.0 standard is 0.5 amps, which is not enough to charge a modern phone. USB 3.0 is 0.9 amps, wall chargers can be as high as 2.4 amps.
https://www.dallasnews.com/business/...ast-as-it-can/
