Exterior lights staying on
Old Mar 25, 2015 | 07:32 PM
thelariat02's Avatar
Hey guys, I need some help before I start replacing parts.
I have a 07 F150 FX4.
When I leave the Multi function switch in Auto position and the lights turn on at night they will not turn off when I turn off the truck. The headlights, fogs, and taillights stay on..
What do you guys think it is or where can I start looking for the problem.
Thank you.
Old Mar 27, 2015 | 04:48 PM
RevBiker's Avatar
relay or a timer??
Old Mar 30, 2015 | 08:24 AM
SSCULLY's Avatar
What modifications are on the truck.
- All, not just what you think might be associated with the symptoms.
Have you checked the VSM for damaged / "burnt" pins ?
https://www.f150online.com/forums/el...eadlights.html
Old Mar 30, 2015 | 04:29 PM
Hid relay, led fogs, gotts intake mod, edge programmer, exhaust. Dual 8" sub's,300 watt amp.
Old Mar 30, 2015 | 05:14 PM
I'll check this out thank you
Old Mar 30, 2015 | 09:17 PM
SSCULLY's Avatar
Next question is: do the autolamps work correctly if the switch is in the auto only position or autolamps and pulled out for the fog lamps ?
Did you do the bambi mod ?
Straight away I see remove the Relay for the HID lamps, and retest.
- Also test it with and without the fog lamp position on the switch activated.
What are using using for the trigger and for + VDC on the amp ?
Old Mar 30, 2015 | 09:43 PM
Pulled the back seat and checked the BDM. all plugs looks fine and ground is good.
Old Mar 30, 2015 | 09:47 PM
Auto lamps have worked for a year with the HIDs. I am running the Motocontrol from the retrofitsource meaning passenger side headlight plug is the trigger.
I did not do the Bambi mod as I don't want my fogs on with my highs (see my other thread I started)
Doesn't matter if my fogs are on or off the lights still won't turn off in the Auto position.
Old Mar 30, 2015 | 09:59 PM
Tested them again. Once with fogs off and once with fogs on.. They do actually shut off, but take about 5 minutes to shut off where before it only took 30 seconds.
Old Apr 1, 2015 | 11:36 PM
SSCULLY's Avatar
Auto lamps have worked for a year with the HIDs. I am running the Motocontrol from the retrofitsource meaning passenger side headlight plug is the trigger. ...<snip>....
And now they don't work.
If you want to diagnose the problem, let me know.
If you want to use supposition instead of getting a meter out and doing the testing, good luck with that.
Old Apr 2, 2015 | 07:56 AM
Never said I wasn't willing to diagnose the problem. Just stating it worked before. You know giving as much information as possible.
And like I said they do shut off but takes almost 5 minutes to do so where before it took like 30 seconds.
I can bring my multi meter from work and start probing connections if I know what connections to check please.
Old Apr 6, 2015 | 06:23 PM
Unplugged HID relay harness. Still does the same thing.
Old Apr 16, 2015 | 11:44 AM
Bump!
Have tried with HIDs unplugged and LEDs off/unplugged. Still doing the same thing.
Old Apr 16, 2015 | 12:49 PM
RevBiker's Avatar
don't know if this is any help or not.
http://ww2.justanswer.com/uploads/mu...25905_1121.pdf
Old Apr 16, 2015 | 05:42 PM
Thanks I'll check that out.
