door lock problem please help
Old Jun 3, 2014 | 06:56 PM
Mustangt69's Avatar
door lock problem please help *resolved*
2001 f150 supercrew door locks and keyfobs quit working. doors do not lock in gear. the rap module was clicking the other day but now nothing. the panic button on the fobs doesnt work either. program mode for keyfobs does nothing, fuse under hood has voltage, fuse under steering wheel doesnt. any suggestions? i already tried replacing the rat module. does this need to be dealer programmed? all this happened after a large rainfall and my tuner cord being messed up causing my truck to not work for 2 days. help please!!
thank you
Old Jun 3, 2014 | 08:39 PM
mjewell00's Avatar
thank you
maybe a shorted/broken wire inbetween the fuse under the hood and the one under the steering wheel? just an idea to start if its not passing power
Old Jun 4, 2014 | 09:36 AM
ishootstuff's Avatar
Windsheild leaking on GEM?
Old Jun 4, 2014 | 11:28 AM
Mustangt69's Avatar
ok rechecked fuse under dash, fuse 29 and 8 are getting power. my voltmeter must have been acting up.. anyways i pulled and opened the gem and that looks good. i also swapped the relays under the oval on the dash. i took a paperclip and tried getting the locks to operate by the relays but no luck. i pulled the door panel and tested the switch and that seems good. probed the pink wires going to the actuator and didnt register 12v+ or ground signal
Old Jun 4, 2014 | 11:30 AM
Mustangt69's Avatar
i also thought i seen the headlights flicker on and off the one day when i was inside the house. the locks went from working great to clicking in the gem and now nothing whatsoever from any door. It doesnt seem to change anything if the rap module is plugged in or not. everything else on the truck works
Old Jun 4, 2014 | 11:22 PM
Mustangt69's Avatar
anyone? bad gem bad pcm? another bad rap module? wiring issue? showed up overnight...went from all locks working to nothing to clicking from rap module back to absolutely nothing.
Old Jun 4, 2014 | 11:26 PM
Mustangt69's Avatar
i still get a blinking "security" after pulling out the keys...is this pats related? anyone know which pinout on the rap module is the 12v+ and the ground? just to make sure its getting power.
Mustangt69's Avatar
also keypad on door doesnt light up or work now either
Old Jun 5, 2014 | 09:36 AM
So the RAP was clicking, now it's silent. I'm going with RAP. Pop that sucker open and look inside. Please forgive my ignorance, but is the RAP the same as the CSM (Central Security Module)? I had a funky issue with one of my Expy's and I made this thread. This thing has several relays inside which control locks and lights as well as being married to the door keypad.
Old Jun 5, 2014 | 10:14 AM
Mustangt69's Avatar
i replaced the rap once and no change...think i have another bad one?
Old Jun 5, 2014 | 10:17 AM
Mustangt69's Avatar
which pins on the rap module can i check for power and ground?
Old Jun 5, 2014 | 10:37 AM
This is for a 1998... I'll keep looking as time permits.
Old Jun 5, 2014 | 10:39 AM
Mustangt69's Avatar
are there any conditions that will disable the door locks and remotes??? like truck in gear or anything?
Old Jun 5, 2014 | 02:02 PM
Mustangt69's Avatar
probed some wires and found constant + and switched + also ground seems good at the connector
Old Jun 5, 2014 | 06:10 PM
Mustangt69's Avatar
2001 f150 door lock problem
2001 f150 supercrew door locks and keyfobs quit working. Lock buttons inside do not work and No buttons on the fobs work including the panic button. Replaced rap module, didn't help cannot enter program mode. Also exterior keypad doesn't work or light up. Everything else works. Truck does not lock doors in gear. All happened after a heavy rain and a programming issue with my edge. Opened gem but looked ok..could this be the issue? Fuses look good but cannot find relays. Locks made clicking through rap but now make no noise. Help! Thanks
