Door Open Chime on Startup
Hey y'all. I just bought this '01 Supercrew with an aftermarket alarm already installed. Whenever I crank it up the door open chime goes off for 5 sets of 5 chimes and it has nothing to do with the door. (ie. this happens anytime I crank it up, door open or closed. It's just the same tone as the door open tone.) Does anyone have any ideas for fixing this or just disabling the door chime deal?
Thanks,
CB
Thanks,
CB
Ok replaced the bulb and the airbag light is always on now. (Explains why it was burnt out.) Do you know what I need to do? I've disconnected the electrical connector from the restraint control module near the floor vent in the past. Don't know if that has anything to do with it.
It stays on. The RCM is definitely hooked back up now. Don't know what else it could be.
Check the airbag (SRS) fuse - if it's blown or missing that will cause the light to stay on.
You may have to take it to a dealer to get a computer diagnostic on the airbag system. Sounds like the previous owner may have had some airbag issues, or it was in a crash and the system wasn't rebuilt properly.
Don't have a fuse chart? There's one in the owner's manual, which can be downloaded from Ford.
