Keyless entry keypad
Old May 28, 2001 | 05:16 PM
TUFFORDJR's Avatar
Post Keyless entry keypad
Anyone have any clue how much a new keypad would cost? A couple buttons stopped working and it is annoying me. Would that fix my problem, or do I have to replace the computer also?
2000 F150 Flareside Super Cab Lariat
Black w/Grey Leather
15% Tint
5.4L Triton V8 3.55LS
4x4 ORP
Jet Chip
Borla Exhaust
K&N Air Filter
ARE Z Series
Penda Liner Pro
PIAA 9007 Platinum Super Whites
PIAA 980 Dual Lamp
PIAA 520 4x4
Billet Grill
Pioneer DEH-P920R CD Head Unit
Pioneer CDX-P1270 Changer
Pioneer GM-X742 Sub Amp
Pioneer GM-X944 4ch Amp
Pioneer TS-C603 6 1/2" Components
Pioneer TS-E1690 6 1/2" 3 ways
JL Audio 10" Stealth Box
Manik Brush Guards
BEL Remote Radar/Laser Detector
Blue Interior Neon
Illuminated Ford Emblems
NR Automotive White Face Gauges
Ventvisors
Bugflector II
Zenetti 18" Vega wheels
TOYO Proxes S/T 285/60/18
Old May 28, 2001 | 07:40 PM
F150Sven's Avatar
Cool
List price is about $72. If you order it from www.fordpartsonline.com it's about $54.
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
All of the above, plus
Sony C7000X HU
Cerwin-Vega SS2502 components(Front)
Blaupunkt PCxp573s(Rear)
Radio-delay mod
Other Enhancements:
Extang Black Max Tonneau Cover
Keyless Entry Keypad
Eurolite Xenon Fusion Bulbs - Headlights and Fogs
Old May 28, 2001 | 08:34 PM
TUFFORDJR's Avatar
Post
Will that fix my problem? Or is it necessary for the computer to be changed as well?? I would think that would fix it.
15% Tint
4x4 ORP
Jet Chip
Borla Exhaust
K&N Air Filter
ARE Z Series
Penda Liner Pro
PIAA 980 Dual Lamp
PIAA 520 4x4
Billet Grill
Manik Brush Guards
Blue Interior Neon
Ventvisors
Bugflector II
Old May 29, 2001 | 08:03 AM
fourhour's Avatar
Post
Are you using the original code or one you assigned to it? Perhaps your code got lost. Try using the original. Just my 2 cents, Dennis
'98 White Super Cab 4X4 Lariat
WustaMass, Where we pahk ah cahs!
Old May 29, 2001 | 02:58 PM
TUFFORDJR's Avatar
Post
I tried using both codes... the 9/0 button isn't working and both of my codes have a 9 in it.
15% Tint
4x4 ORP
Jet Chip
Borla Exhaust
K&N Air Filter
ARE Z Series
Penda Liner Pro
PIAA 980 Dual Lamp
PIAA 520 4x4
Billet Grill
Manik Brush Guards
Blue Interior Neon
Ventvisors
Bugflector II
Old May 29, 2001 | 06:15 PM
harleyrules's Avatar
Post
Does your remote work? If so, then it is the keypad that needs to be replaced..
HD F150
2000 FLHTCUI
1970 OLDS Cutlass W 31
2000 Lincoln LS
Old May 30, 2001 | 08:23 AM
TUFFORDJR's Avatar
Post
Yeah the remotes work fine... just a couple of the buttons don't work. Just wanted to make sure that a new keypad would be compatable with the existing computer. Is anyone else having this problem?
15% Tint
4x4 ORP
Jet Chip
Borla Exhaust
K&N Air Filter
ARE Z Series
Penda Liner Pro
PIAA 980 Dual Lamp
PIAA 520 4x4
Billet Grill
Manik Brush Guards
Blue Interior Neon
Ventvisors
Bugflector II
Old May 30, 2001 | 10:41 AM
Shark99's Avatar
Post
the kepad is just a plug an go...you can replace it at will, should take about 30 minutes start to finish. Replacing it will have no effect on your PATS computer.
2000 XLT Silver 5.4L SC 4X4 ORP 157"wb Ford Floormats, MudFlaps, Cabin Air Filter, lighted emblems, lighted interior door handles(all 4) Chrome Grill (4x2 style), Diamondplate bed caps, Pro-Tech tool box, Air Box mod, Muth Heated Signal Mirrors, Custom Gauge Pod-(water temp, trans temp)
Perma-cool 8" Electric Trans Cooler Fan, 2.02" Radiator, 16" Derale cooling fan, Superchip (flipchip), Map lights in overhead, tinted windows, back up lights, soundproofed cab.
Old Jun 3, 2001 | 09:24 PM
skicrave's Avatar
Post
A couple of things:
First, your truck is a 2000, your keypad should be covered under warrenty.
Second, I just did the keypad install, and I was wondering where the others that have done it routed the wiring harness. I ran it between the window channels and the inner panel of the door. Does anyone see any problems with it being there. When I was putting it in, that is where it looked like it would be least intrusive. Just wondering what others did.
Jason
Old Jun 3, 2001 | 10:39 PM
TUFFORDJR's Avatar
Post
Not under warranty any more... over 36k
15% Tint
4x4 ORP
Jet Chip
Borla Exhaust
K&N Air Filter
ARE Z Series
Penda Liner Pro
PIAA 980 Dual Lamp
PIAA 520 4x4
Billet Grill
Manik Brush Guards
Blue Interior Neon
Ventvisors
Bugflector II
Old Jun 4, 2001 | 10:38 PM
F150Sven's Avatar
Cool
skicrave,
I ran mine between the inner door and the trim panel. I didn't feel like putting it inside the door. As long as you have secured it to keep it away from the moving parts you should be alright. I pulled the plastic clips off the harness and relocated them with electrical tape to pick up the existing holes instead of drilling new holes.
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
Other Enhancements:
Old Jun 5, 2001 | 06:27 PM
LoNE WoLF's Avatar
Thumbs up
Howdy Tuff,
Mine did the same thing, dealer replaced just the keypad and has worked flawless since.
Good Luck
2000 F-150 Lariat, Flareside, Black, SC, FOxFO, 5.4L, 4R70W TranZ, 3.55 Limited Slip Rear Axle, Garmin Street Pilot Color GPS, Bed Rug, ExTang Saber Tonno, CatchALL Floor Mat's, VentShade Visors, Limo BLaCK Tint'd Windows, PIAA Platinum Super White Headlight Bulbs with XTra Technology, FLoWMaSTer 40 Series MuFF, Mobil 1 5W-30 and Motorcraft 820-S Filter, SuperFReaKiN - FLiPCHiP Cal'd for Regular and Premium FueL,
Soon..............
AiRaID FIPK, Expedition Front and Rear Sway Bars, F-1 HooD, P305/75/R17 BFG KO's, 3" Body LiFT
www.tnugent.com/
Old Jun 14, 2001 | 07:51 AM
S'CrewLoose's Avatar
Post
Tuff,
Even with over 36K, I would think a good dealer would at least entertain the idea of replacing it under warranty. At about a year old with that kind of mileage, the only way to wear out the keypad is to have someone riding on the step locking and unlocking the door as you drive
01 S'Crew XLT 4X4
Arizona Beige/Wedgewood Blue
5.4L
3:55 Limited Slip
Off Road Package
Moonroof
Sliding Rear Window
6 CD Changer
Class III Tow Group
Bed Xtender
Built 04-12-01
Appearence Mods.
DuraLiner BedLiner
BUGFLECTOR II
Donmar Moonroof Wind Deflector
Husky Liner Mug gaurds
Old Jun 15, 2001 | 12:56 AM
TUFFORDJR's Avatar
Post
You think ANY dealer is going to do ANYTHING when the warranty is up?? I have to replace the GEM module too... but minor expenses... no biggie... I love my baby!!
15% Tint
4x4 ORP
Jet Chip
Borla Exhaust
K&N Air Filter
ARE Z Series
Penda Liner Pro
PIAA 980 Dual Lamp
PIAA 520 4x4
Billet Grill
Manik Brush Guards
Blue Interior Neon
Ventvisors
Bugflector II
