HELP - Locating reverse gear wire
I'm trying to install my Back-up monitoring system and it requires that I hook up one of the wires to the reverse gear wire. I thought about connecting it to the reverse light wire but I was wondering if anyone knows where it is located and the wire color inside the cab? Since the monitor will be inside the cab, It'll be much simpler if I can connect from the inside rather than from the back of the truck.
Appreciate your help!
axelrod, if your truck has a trailer plug at the back, then you can access the reverse wire under the hood in a harness leading to the back. This is the closest I've found when I install navigation units in. hope this helps.
2000 EXPEDITION 4.6 3.31 Rear, Poweraid Spacer, UltraFlow muffler, 6.8 inch TV with tuner/VCP, Full alarm and Auto-Start.
New Addition:
2001 F150 SUPERCAB 5.4L 3.55 LS, Airaid FIPK, Full alarm and auto-start, 50 series 3 chamber 3inch in/out Deltaflow Flowmaster
Swept Side style, Beltech 2 inch rear shackles, SUPERCHIP, billet grille, Lariat wheels and tires (275/60/17), Billet antenna by TRENDZ, Daytime running lights(if I can get it to work), Lightning 180 degree thermostat, White face gauge insert with EL lighting, Custom stereo system currently in the works.
COMING SOON:
pulleys, remove cats, 2 inch drop all around.
New Addition:
COMING SOON:
