Ford Autolamp System
Old Apr 26, 2001 | 11:10 AM
CBechtel's Avatar
Question Ford Autolamp System
I have a 2000 F150 XLT. I studied the factory wiring diagrams very carefully and concluded that all the necessary wiring was included in my vehicle so I could install the autolamp function. I purchased (1) a new switch assembly (w/autolamp function), amplifier and dash cover (w/cutout for the sensor). All the wiring hooked up perfectly. Nada, the autolamp function does ot work. Any ideas? Do 150's w/autolamp function have a different GEM? If any of you electrical gurus have any ideas, I would be most appreciative!
Old Apr 27, 2001 | 07:40 PM
turbo497's Avatar
Post
did the same on mine it works perfectly! I too have a 2000 f150xlt. I don't know why yours is not working my amp part was yl3z-13a018-aa and the switch was sw-5558
yl3zb-11654-dab are these the parts you used?
Old Apr 28, 2001 | 10:30 AM
Bent6's Avatar
25 Year Member
Post
Is there A fuse in the fuse box for that circuit? I'd start by looking for power at the autolamp module plug. My 97 electrical manual says pin #1 (end of plug with locating tab or as you would view it the locking clip on top) is hot in start or run, #4 is power and is always hot.
97 XLT S/C Long Bed 2wd, 4.6 Romeo, 4R70W trans, 204,000 miles
Old Apr 28, 2001 | 10:37 AM
Bent6's Avatar
25 Year Member
Post
My 97 book shows fuse # 4 as the one for autolamp module along with the park lamp relay, headlamp relay, RAP module, and power mirror switch.
Old Apr 29, 2001 | 08:11 AM
TRUSSMAN's Avatar
Question
I like this idea! Roughly what was the cost for parts? thanks!
2000 XLT SUPERCAB, black, captian chairs
4.6 AUTO
ARE COVER
FLOWMASTER 40 si so, 3" air inlet to stock air box silenicer removed
Old Apr 29, 2001 | 01:38 PM
turbo497's Avatar
Post
ABOUT $160.00 FOR ALL PARTS. just as a note I did not have to mess with fuse box parts worked as soon as I pluged them in
Old Apr 29, 2001 | 02:40 PM
CBechtel's Avatar
Smile
Got them to work yesterday! Rechecked my installation and I did not have the plug on the amplifier properly connected (was not pushed in all the way). Also, I found it necessary to do a small adjustment with the yellow screw on the amplifier. Thanks all! It is nice that Ford includes all the wiring in its vehicles. I've also installed the factory DRL's and they work great too. If you purchase the parts, be sure to furnish your dealer with your vehicle's date of manufacture. For example, my 2000 was built on 5/6/00. All vehicles built after 5/10/00 require a different headlamp switch. I don't know what the difference is, other than Ford's part #.
Old May 10, 2001 | 02:46 PM
ane182rf's Avatar
Post
Dude, like what is the part number for the dash cover w/cutout?
98 4x4 SC E4OD, 9.75 3.55LS, Tranny Cooler, Heavy Duty package in disguise.
Old May 11, 2001 | 10:56 AM
summitman's Avatar
Question
what color dash do you have?
98 f150 4.6 auto 4x4 supercab-short box/bright red & black/6 disk cd changer/ dynomax cat back/k&n fipk/super chip/lund taillight covers/factory fog lamps/Ford mud flaps/pace edwards box cover/ultra wheels/LT265-75-16 BFG/ westin nerf bars/steel horse billit grill & bumper insert/reflex shocks/bosch plat. plus 4/accel wires/auto start/left hand grab handle/2001 lighting headlamp and corner lights/2002 Ski-Doo Summit 800 High Mark X
Old May 11, 2001 | 01:25 PM
CBechtel's Avatar
Smile
The Ford Part # for the Dark Graphite Color Dash Cover w/cutout for sensor is:
XL3Z-15046A34-DAA
Perhaps this will put you on the right course for other colors.
