keyless lock door handles
Old 06-02-2000, 02:19 PM
dogsailer's Avatar
Post keyless lock door handles
Has anyone retro fitted the driver's door handle with the keypad for keyless entry?
I need to know if this is possible and the appropriate part numbers/cost and how much hassle this is to install. Tried to get info from the local Ford parts counter but didn't have too much luck.
Excercise your 2nd Amendment rights at www.auctionarms,com.
Old 06-06-2000, 12:31 AM
RBurton's Avatar
Post
Complete instructions are at:
http://www.scomm.net/~smithm/index2.html
Click on the letter "K", for keyless.
[This message has been edited by RBurton (edited 06-05-2000).]
Old 09-24-2000, 01:23 PM
Lariat's R Us's Avatar
Post
RBurton, Tried to get the instructions from the site you mentioned but was unable to connect. Experience indicates that it could be spelled incorrectly. Is this true or has the site shut down. Thanx, Dennis.
Old 09-24-2000, 02:37 PM
Kelly's Avatar
Exclamation
http://www.fordf150.net/howto.htm
1998 F-150 XLT 4x4 SC/SB 4.6L, Auto., 3.55LS, TTP, blah, blah, blah
All the info is at http://www.fordf150.net
Now with How-To Articles!
Old 09-25-2000, 01:39 PM
Post
Kelly, Thanks for the link. Went to it and found it to be very informative. Can't get back to it now though. It looks like scrambled eggs. Few questions. Do all F150's have the required computor module allready in place? Does this work for a 98 Lariat? Is the handle sold in color or does it need to be painted? TIA, Dennis.
[This message has been edited by Lariat's R Us (edited 09-25-2000).]
Old 09-27-2000, 10:46 PM
Kelly's Avatar
Exclamation
Lariat'sRUs,
Send me an e-mail - kelly@fordf150.net - with details on the problem you were having viewing my site, and I'll try to help!
As far as I know, only F-150's with the remote keyless entry from the factory have the necessary RAP module. That's because there is a 5 digit code on it that is the unlock code for the keypad.
This is from part 2 of the article:
The part number for the keypad is YL3Z-14A6266-AA, and the number for the handle is as follows: XL1Z-7822405-BAK Silver (YN), XL1Z-7822405-DAB Red (E4), XL1Z-7822405-BAJ White (Y0), XL1Z-7822405-BAH Black (UA).
The dealer would be able to confirm these codes for sure.
Old 10-11-2000, 11:26 AM
fourhour's Avatar
Question
Okay, Let's try another approach on this one. I'm confident someone out here has built them a hotrod and put the keypads on it. Found a similar product at 12volt.com which you place an object on the window that senses a predetermined code and unlucks the doors. Any other sites with similar keypads that may be retrofitted like original equipment? Thanks, Dennis
Quick Reply: keyless lock door handles
