tempermental window washer sprayers
Old Jan 4, 2010 | 08:54 PM
tja349's Avatar
when i push in the button the wiper always work but totally radom the sprayers do not work- broke more than working especially in the winter .. a buddy of mine had a similar prob but the wipers wouldnt work either to fix his he just wired them both to a toggle switch is there a way to fix it and stay stock?
Old Jan 4, 2010 | 11:05 PM
SSCULLY's Avatar
Have you checked to see if the lines are plugged ?
Maybe check the bottom of the reservoir to see if there is something in the bottom, blocking the fluid from getting pumped out.
Old Jan 4, 2010 | 11:21 PM
Harper 184's Avatar
I had a 97 f150 that done the same thing...but i was told that it is in the switch itself..they told me to take it apart and clean the contacts or just replace the switch...i never got around to fixing it before i sold it. but it maybe worth a shot to take it apart and clean it.
From what i understand it was a common thing for 97-99.
Old Jan 5, 2010 | 08:46 AM
SSCULLY's Avatar
Harper_184 has a good point. Along with checking the system, you can check the end of the MFS. Usually this is associated with ghost wiping problems, but worth a check.
Here is a thread on the topic :
https://www.f150online.com/forums/el...on-switch.html
Old Jan 7, 2010 | 02:24 PM
tja349's Avatar
yea its def not clogged bc it works sometimes ... would u clean the inside of that with something like electronic parts cleaner? im guessing this is the issue
Old Jan 7, 2010 | 04:02 PM
SSCULLY's Avatar
Originally Posted by tja349
yea its def not clogged bc it works sometimes ..<snip>...
Actually, this is guessing it is not clogged.
Definitively not clogged is you removed the reservoir, washed it out several times, to make sure no clear plastic ( like the one that is usually sealing the washer fluid bottle ) is in there, that can get sucked to the output of the tank and blowing the lines out with low PSI compressed air, and then testing them by plugging the end, and applying vacuum to make sure it holds.
Don't know long this has been going on, but you might also want to check the washer nozzles, to make sure they are not frozen or blocked.
..<snip>.. ... would u clean the inside of that with something like electronic parts cleaner? im guessing this is the issue
Normal contact cleaner is a good item to use to clean the contacts in the switch.
Old Jan 9, 2010 | 04:53 PM
tja349's Avatar
its been happening for a few years it actually may be clogged bc for the 1st time it worked on one side and not the other now neither work ill try blowing it through thanks
Old Jan 19, 2010 | 05:21 PM
tja349's Avatar
ok its not clogged blew out the lines air out the end and bubbles in the tank... so i cleaned the contacts it helped my wipers work better but the pissers still dont.. i tested the motor by hooking it up right to the battery worked great.... think its the contacts still? how can i repair or replace it?
Old Jan 19, 2010 | 06:21 PM
SSCULLY's Avatar
You can test the MFS, to see if you need to replace it.
This is the plug on the MFS, so you will need to remove the steering wheel column cover. 3 screws on the bottom, to release the 2 halves.
I remove the ign key tumbler, as not to stress the plastic too much ( cold / old could crack ). This is the 4th hole from the bottom.
Directions in this thread by JMC on removing the ign key tumbler.
https://www.f150online.com/forums/el...beep-beep.html
This is the best route to check with your Ohm meter, what is going on with the MFS prior to spending the money on a new one.
Old Jan 19, 2010 | 08:41 PM
tja349's Avatar
thanks scully
Old Jan 21, 2010 | 02:49 PM
tja349's Avatar
well i decided to just bypass the regular switch and put a push pull switch right behind the wiper lever i cut the wire behind the harness and the pump and spliced it there and put a fuse before the battery works great just fyi
