Using the PHP Edge, is there a way to pull the
Code for the door unlock pad?> The factory code? For some reason, probably when I was messing with my HID's and disconnecting the battery, it reset! I didnt know it and made the mistake of locking my keys in the truck thinking I would just use the key pad. Can the Edge pull the factory code?
Thanks!
Thanks!
Thanks!
Thanks!
I simply can't understand how a battery disconnect would erase your keypad code. I'm certain you HAVE to enter the factory code to do that.
Are the buttons lighting up when you push them? Have you checked the fuse? I'm not finding one to the keypad itself, but #107 is to the BSM for the door locks.
Failing that, it's possible one of the buttons has become faulty. It happens.
But, as has been pointed out, the code is on a label on the BSM behind the rear seat. Here's a link to rear seat removal: https://www.f150online.com/forums/ar...08-my-way.html
And, this thread really belongs in the Electrical Forum, so I'm moving it there.
- Jack
- Jack
