Hid relay question
Old Apr 7, 2009 | 04:28 PM
rex4mayor's Avatar
Well when I first installed them, the "instructions" said to hook them up to the factory headlamp connector, they were "plug and play" HIDs. They aren't installed right now, I have my stock headlights in there.
Old Apr 7, 2009 | 04:37 PM
SSCULLY's Avatar
OK, hope you got a great deal on that setup, it is junk.
Do you have a low beam only, or both high and low ?
Old Apr 7, 2009 | 04:38 PM
rex4mayor's Avatar
Just the low beam.
They had good feedback, and I had friends that bought from them and had no trouble.
Old Apr 7, 2009 | 05:05 PM
SSCULLY's Avatar
Good luck to them long term, that is a really bad design for adding HID lights.
If there is not a problem with what they are sending you for product, this will do much better.
What it sounds like you have today
What you should install
That should do the trick, again if there is nothing wrong with the equipment. If they took that type of short cut with the design, don't know what the quality of the product is going to be like.
Old Apr 7, 2009 | 05:23 PM
rex4mayor's Avatar
Ok, that's what i was lookin for.
thanks for taking the time to explain this.
Old Apr 7, 2009 | 05:56 PM
JohnsonN's Avatar
TRY THIS FIRST
Sand your Ground, where you tie the ground wire, SAND it to Bare Metal. Speacially the flicker one. Try That
Most importance but usually miss out is a good solid ground conection
