Blinker problems
Old Mar 11, 2009 | 09:58 PM
suavehorn's Avatar
Blinker problems
Ok, I have a 99 f150 supercab and I currently do not have any blinkers working. My hazzards work but when I need to make a turn and hit the turning signal, nothing comes on.Not either side comes on. I do hear 1 click when I hit the switch bit nothing else. So guess what?? I get pulled over by a cop and thankfully he gives me a warning. So what can be causing this and is it an easy fix? your assistance is needed immediately. Thank you in advance.
Old Mar 12, 2009 | 09:11 AM
SSCULLY's Avatar
If the hazards work, I would say it is the MFS.
The diagram at the MFS shows where the Haz and turn signals feed in, and out, using the same connectors.
You did not say, but do your normal brake lamps work ?
Do the turn signals work in the lane change position ?
If you want to remove and test the MFS, here is the testing chart for it.
New MFS switch is ~ 90.00 + S/H at online sources.
1999 - Ford -F150 -> Mechanical catalog
Electrical -> Chassis Electrical -> Switches -> Multifunction Switch
Old Mar 12, 2009 | 10:47 AM
Richard D's Avatar
Yep I'm with Scully sounds like the Multi Function Switch
Old Mar 12, 2009 | 11:08 PM
suavehorn's Avatar
Thanks Sscully. Yes my brake lamps work. I do not know what you mean when you ask if my signals work in lane change position??? Also, where is the MFS located and how easy is it to replace? Again thanks for your reply
Old Mar 13, 2009 | 08:37 AM
SSCULLY's Avatar
The MFS is the Multifunction Switch. The turn signal level that also had the wipes and high beam switch on it.
It is not too bad, you have to pull the top and bottom covers for the steering wheel column and then unscrew the MFS from the mount, and remove upwards.
Here is a tread on a Taurus MFS, should look similar. This thread was problems with the wipers.
Old Mar 18, 2009 | 02:45 PM
suavehorn's Avatar
so you are saying if none of my blinkers work, but my hazards, wipers work, that it is the MFS correct? And to get to it and replace it, I need to go into the sterring column correct? Also, you never put a link at the end like you mentioned. Thanks in advance
Old Mar 18, 2009 | 07:12 PM
SSCULLY's Avatar
Sorry, all over the place with that useless posting ( I'll remove another one from the post count )
If the Hazards work, but the turn signals do not, then the problem is contained within the MFS itself, vs the connector in the steering column.
That is another problem, that does not seem to fit your symptoms.
Before replacing the MFS, remove it and test it, don't spend the money until you are sure.
Here is the thread this time ( again sorry lousy editor on that posting )
https://www.f150online.com/forums/el...on-switch.html
Old Mar 20, 2009 | 01:16 AM
suavehorn's Avatar
Thanks Scully. Noiw just in case it is not the MFS, what is the other possibility?
Old Mar 20, 2009 | 09:15 AM
SSCULLY's Avatar
If the MFS tests good on all circuits ?
The next step is to check the connector back for a good circuit, but we know that is the case, the hazard functions correctly.
Best to remove the MFS, and test it per the chart above.
Old Mar 26, 2009 | 10:03 PM
suavehorn's Avatar
Where should I purchase one at? I called a Ford dealer and he quoted me like 169.00 for it!!! Also, I read another thread about this problem where a guy cleaned and lubed it and it worked for another 5 years. If it is bad, can it be fixed just like that? thank you sir for all of your help
Old Mar 26, 2009 | 11:16 PM
SSCULLY's Avatar
You can try cleaning it, but if the contacts have been corroded for some time, the plastic could be warped. If you feel like it, worth a try after testing it, to confirm it is bad.
If you want to get one online, they are much cheaper ( odd part, that dealer quoted you 3.00 above list price ?? )
Multifunction switch, f150
f150 1997-03, heritage 2004
MSRP : $166.53
online price :$89.18 + S/H
What happened with the testing ?
Old Mar 27, 2009 | 10:00 PM
suavehorn's Avatar
MSRP : $166.53
Did not test, i just feel like buying one since it most likely is bad and am I not good at testing, Im better at replacing, lol. Where online can I buy it? I looked on ebay and they have every year but 2009.
Old Mar 27, 2009 | 11:26 PM
SSCULLY's Avatar
2009 ?? do you mean 1999 ? Your profile says 1999, and that is what I have been referring to.
Dealers in no particular order :
www.fastpartsnetwork.com
Fast Parts Network, LLC
652 Nautical Way
St. Augustine, FL 32080
Sales:
sales@fastpartsnetwork.com
www.southwestfordparts.com
Southwest Ford
3000 Fort Worth Highway
Weatherford, TX 76087
V: 817-596-8074
Keith Sexton Asst. Parts Manager
www.fordpartsonline.com
Bob Utter Ford
2525 Texama Parkway
Sherman, TX 75090
v:866-941-FORD
www.tascafordparts.com
F150online.com Site Sponsor
Tasca Automotive Group
1300 Pontiac Ave
Cranston, RI 02920
v: 800-915-3141
www.thinkpartsguy.com
1100 Oyster Bay Ave South
Bremerton, WA 98312
www.directfordparts.com
Silver State Ford
2121 E SAHARA AVE
LAs Vegas, NV 89104
www.tituswillfordparts.com ( previously fordparts.com )
Titus - Will Ford
3606 S. Sprague Ave.
Tacoma, Washington 98409
v: 800-637-6876
Good luck, hope it is a bad MFS and not something else.
Old Mar 28, 2009 | 12:40 AM
suavehorn's Avatar
Thanks Scully, you are awesome!! I hope so too! And yes i meant 1999 lol
Old Mar 28, 2009 | 01:34 PM
suavehorn's Avatar
http://www.am-autoparts.com/AM/Switc...-/AM-48494385/
Would you reccomend this place? They have it for a very reasonable price.
