airbag code 16?
Old Feb 18, 2009 | 09:01 AM
donjuan2002's Avatar
airbag code 16?
It's for a 2008 F150. Does anybody know what this code is and how to fix it?
Thanks,
Old Feb 18, 2009 | 12:01 PM
cva-59's Avatar
air bag code 1-6
LFC code 1-6 , DTC B-2290 is for occupant classification system fault Dont even try to diagnose what the problem is. You have a warranty on the vehicle just take it back to the dealer.
Old Feb 18, 2009 | 01:20 PM
Salvage vehicle = no warranty
I'm fixing this on my own dime. I think this is an issue with the seat belt buckles if I'm not mistaken.
Old Feb 18, 2009 | 06:57 PM
cva-59's Avatar
air b ag code 1-6
This ia fault with passenger sida seat belt pretensioner, wiring terminals or connectors, ocs system component or rcm module. You do not state if vehicle was in an air bag deployed accident or not. The pretensioners are activated by the RCM if the safety belt is buckled(occupant or not) There are tests to need to be done. You should get a hold of a factory manual if you can as there is a system procedure to follow
Old Feb 18, 2009 | 09:28 PM
No airbags deployed. The truck got water just below the glovebox. Which manual are you refering to? I have a FORD Wiring Diagrams manual, but I do not think there are trouble shooting steps for the airbag system. Thanks for the help so far. I just ordered the seat wiring and belt buckles for both sides. The floor harness and the dash harness have already been replaced. The airbag module seems to be working okay since it has done a good job throwing the codes.
Old Mar 6, 2009 | 12:25 AM
I found my problem!
It was a bad passenger side seat belt! There is a connection to the floor harness on the pillar that was bad. I went ahead and ordered new front seat belts and after the installation, the airbag system initialized perfectly.
Old Mar 11, 2010 | 02:44 PM
itsmekbw's Avatar
hey where did you get your seat belt from im in the army in germany so i need to find a company to ship out here
Old Mar 12, 2010 | 10:28 PM
I bought it at my local FORD dealership here in Houston. I am not sure if they ship or not. Just walked up to the counter and ordered them. A few days later, I just picked them up.
Old Mar 15, 2010 | 05:39 PM
itsmekbw's Avatar
k thanks can you get there number so i can get a hold of them if you just happen to walk down the street one day?
Old Feb 25, 2019 | 11:45 AM
jahomaro's Avatar
airbag light 16 code
Hi Guys,
I got a 16 code airbag issue in my 2008 F150 STX regular cab, I dismounted the passenger seat, I found a cut harness, I could not find whre this came from, can somebody please share a picure of the seat ( under) or share a diagram? here is a picture that shows the cut harness. Thanks!
Old Feb 25, 2019 | 12:55 PM
projectSHO89's Avatar
Originally Posted by jahomaro
Hi Guys,
I got a 16 code airbag issue, I dismounted the passenger seat, I found a cut harness, I could not find whre this came from, can somebody please share a picure of the seat ( under) or share a diagram? here is a picture that shows the cut harness. Thanks!
If you do not identify what you are working on, no one can help you.
Old Feb 25, 2019 | 01:37 PM
jahomaro's Avatar
Hi projectSHO89, what you mean? I gave a brief explanation on my issue, airbag light is on, it flahses 16 times, based on what I investigated there is an issue on occupant clasification system, my thought is thet is about something related to that harness that is cut ( see the picture attached in last post). any idea? Thanks,
Old Feb 25, 2019 | 02:45 PM
He's asking for vehicle details - year, model, etc.
Old Feb 25, 2019 | 02:51 PM
jahomaro's Avatar
Got it: F150 2008 STX regular cab.
Thanks,
Old Feb 25, 2019 | 02:52 PM
jahomaro's Avatar
Thanks!
