whacky gauges
Old 12-03-2008, 01:01 PM
strainsa's Avatar
whacky gauges
When I start my 2000 V-6 all six gauges (RPM, MPH, oil temp, etc.) peg high for about 2 seconds then peg low for 2 seconds then return to normal. The only repairs I have ever had was the replacement of the alternator about a year ago. I was thinking there might be a relay or switch that is causing the gauges to go whacky on startup. Any ideas on what it might be??
Old 12-03-2008, 01:17 PM
NoLongerJeepin's Avatar
Time for a new battery
This is a classic sign in these trucks of a battery going bad. Run by walmart and grab a new one for pretty cheap.
beckerjs's Avatar
your battery is going out, change it
Old 12-03-2008, 01:29 PM
JackandJanet's Avatar
X3 - This is called "gauge sweep" and seems to be a symptom of low battery voltage. There are several posts on this in the forums.
- Jack
Old 12-04-2008, 03:49 AM
code58's Avatar
You also need to make sure that the cables (all connections) are clean and tight. Poor or loose connections can cause the same thing.
Quick Reply: whacky gauges
