Autolamp Adjustment?
Old Oct 14, 2008 | 09:33 PM
Denny's Avatar
Sorry if this has been asked before, I did a search and didn't find a clear answer.
How can you adjust the autolamp feature to have the lights come on a little sooner as it gets dark.
On my way to work I drive thru shadows and the lights are coming on and off frequently.
Also, I had somebody pull out in front of me the other evening. I later relized my lights were not on yet.
Old Oct 15, 2008 | 03:41 AM
Klitch's Avatar
huh? ok i gotta watch this thread, i thought autolamps just turned on with the key, off when the timer elapsed.
Old Oct 15, 2008 | 11:35 AM
JackandJanet's Avatar
I don't think there's any way to make the headlights come on at a higher light level, short of maybe partially "blocking" the light sensor on the dash so that the truck "thinks" its darker out than it really is. You might try doing that with some electrical tape or something. If you could figure out a way to put a piece of shade cloth or screen over it that might work too. You don'd want to block too much of the light or you'll be on full bright all the time.
I think having headlights on during the day at reduced intensity is a BIG safety feature and so I installed a DRL module in my truck. It involved cutting into about six wires behind the dash, which was a bit scary, but the results were worth it.
- Jack
Old Oct 15, 2008 | 11:54 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
The dealer adjusted my 1999 after I complained the feature was useless.
The lights came on way after I was comfortable driving.
I don't know that it is an owner adjustment.
They made mine more sensitive to lack of light.
(turned a screw under the dash, in line with the sensor location)
Old Oct 15, 2008 | 04:43 PM
momalle1's Avatar
There is no adjustment on the 2004+ system unfortunately. There used to be an adjustment on the sensor. JackandJanet has the best possible solution.
Old Oct 16, 2008 | 08:15 AM
06 So Comfort's Avatar
I don't know how this will work, but it may be worth trying: Take a highlighter and paint the surface of the sensor. Easy to clean off if it doesn't work.
Old Oct 16, 2008 | 10:16 AM
Turn the switch manually until its dark, not hard lol. I usually run my parking lamps and fog lamps at the shade/dim time of the day because I dont want my headlamps on just yet, but still want to aware the fellow motorists.
Old Oct 16, 2008 | 11:09 AM
Caforddude's Avatar
I think DRL's are great and DO add to visibility. Does Ford offer them on their F150 line?
Old Oct 16, 2008 | 11:45 AM
Agree 100%! I'm sure you can get them as an "option". The DRL module I bought and installed was a Motorcraft product. It cost me a bit under $70 (including shipping), from Millennium Ford. You can also buy the module at a dealership and they can install it (for a lot more money).
Fords sold in Canada have to have them by law, so they're standard on those trucks. Ours have what looks like the connector for the DRL relay behind the left headlight, but there's no wires to it and it's missing the electrical connectors.
The module works great! Lights are on at reduced intensity anytime the engine is running unless you set the parking brake, then they're off (which lets you work on the truck with the engine running without the lights).
- Jack
