Help With Foglights!
Old Jul 31, 2008 | 09:23 AM
  #46
Cajun Storm's Avatar
Originally Posted by blackedoutV6
haha i think i could pull it off
thats pretty much my only option if i wanna use the factory harness though right??
EDIT: theres definately no wire at plug 2....theres one indicator light on the foglight switch that has never lit up..its kinda down and to the right of the ****..i know it has to light up cus i can see a bulb directly behind it
I thought I saw a picture of the fog lights illuminated in this thread?
If the fog light indicator has not illuminated...then YES run a 12v feed line to the pin 2. I would recommend putting an inline fuse before it feeds the HL switch, so you have some circuit protection. Whatever the fog light manufacturer recommends should be sufficient. That way your switch is protected too.
Old Jul 31, 2008 | 02:11 PM
  #47
blackedoutV6's Avatar
i think yall misunderstood that picture or something cus im pretty sure theres a completely seperate light for the foglights
so i can just run any 12V line to pin 2?
and ill do the ILF
any ideas on why theyre still not working tho?
Old Jul 31, 2008 | 02:20 PM
  #48
double post :o
Old Jul 31, 2008 | 05:47 PM
  #49
You should be able to run any fused 12V line to Pin 2 but you'll still need to run a line from Pin 5 to the relay socket pin 1.
Old Jul 31, 2008 | 05:52 PM
  #50
i ran the line from pin 1 to pin 5 last night..
Old Jul 31, 2008 | 07:53 PM
  #51
Well sounds like you're 1/2 way there!
Old Aug 1, 2008 | 01:06 AM
  #52
haha oh yeah!!
but would just missing that 12V for the indicator light make them not work at all?
Old Aug 18, 2008 | 01:55 AM
  #53
bump...maybe? lol
pretty sure all the wires are where theyre supposed to be and still nada
Old Aug 18, 2008 | 01:21 PM
  #54
You got 12V to pin 2 and pin 5 and still nothing?
Old Aug 19, 2008 | 12:35 AM
  #55
yessir lol
im gonna try to take a stab at it again tomorrow so im gonna double check everything ive done so far..
Old Aug 19, 2008 | 11:22 AM
  #56
With 12V at pin 2 and pin5....when you put on the lights and fog lights (i.e. you pull out on the headlamp switch....) Do you get 3 of the lights in Post #13 as well as a 4th (mine's yellow)?
You do have your hi-beams off right?
Old Aug 19, 2008 | 12:27 PM
  #57
yes they are on...although theyre always on, even when i dont have the fogs "on"
and only one of my hibeams work so no, i never have my hibeams on
